6.4L Milleage Update
I have 3,600 miles on my F350 6.4L SRW w/3.73 rear end. I made my first towing trip with it over this past weekend. I averaged 7.3 mpg towing 14,800 lbs. for 300 miles with quartering moderate winds at speeds generally between 60 and 65 mph over mixed terrain from flat to moderately hilly.
I talked to a guy next to me in the campground who drove about the same route pulling 16,900 lbs. with a 2006 F350 6.0L w/4.10 rear end who told me he averaged 12 mpg driving 65 to 70. He seemed like an honest guy who wasn't lying.
Even if my truck improves as much as 20% with more break-in, I still would not be at 9mpg. Therefore, it looks like this 6.4L might turn out to be a real fuel hog. Sucks for me!
on
The 6.4 seems to be capable of delivering 15 mpg and up, but you will not see the same mpgs as the older diesels trucks that were lighter, and had less emission controls.
mpgs will improve as the engine wears in, but you won't see the same mpgs that some folks associate with diesels. Besides, these engines were built for power, not so much economy.
Although, I am at a loss as to how its even possible for a diesel of that size to only get 5-6 mpg. If my 6.9 did that, there would probably be a black smoke cloud to cover the whole west coast (13mpg is what I get if I drive like I stole it on the freeway).
Originally Posted by a-rod
Man thats terrible..... This is my only real gripe with the 6.4. Supposedly theres a new flash out that is suppose to help mpg some, I would definatly go try and get it.
Nick
7.3mpg is still pretty low, but after reading some of the mpg's on the 6.4L PSD...one thing that seems to help is the FORD fuel additive. IMHO...it should not be necessary, but then again...it does appear to help. Maybe while towing...it might be advisable to use. Seems to cut the regen cycles down also...which will help mpg.
Good luck...
biz
on
Adding an aftermarket overdrive was popular back in the late 80s before overdrive transmissions were common place in HD pickups, if its possible to add a unit like say, the gearvendors overdrive, it would go a long way to compensating for the big gears that the new superduties have.
I suspect its only a matter of time before we see these units making a comeback on the big fords.
6.4L PSD Comments & Questions on Comments
Thanks much you guys for your replies. As you might guess, I'm feeling pretty damn bad and quite stupid for dropping 45 grand on this 6.4L when anyone with good sense would have waited a year to find out how it really performed instead of listening to Ford's hyper-hype.
I like the idea of someone coming up with a flash to improve the 6.4L fuel mileage and I would buy it in a heartbeat. How would I know when something like this became available???
I'll definitely try the Ford fuel additive and let you know if it helps. It would be a good thing if we could keep this thread going so we could continue to report on this whole low fuel mileage issue with the 6.4L. How can we do that?
Does anyone know if it is possible/practical to switch the rear end from 3.73 to 4.10??
How can we reach a larger and larger audience with this issue until maybe, just maybe, we get Ford's attention? That is, if they even give a rat's patoot about it.
Best,
T-Trash
Best,
T-Trash
I have a 08, F350, 6.4 and pull approximately 10,000 lbs. My overall mileage while towing (60-65 mph) is 9.8 to 11.5 depending on the terrain.............I have noticed, that if I tow in overdrive, my mileage reduces drastically because of constantly giving it more accelerator in order to maintain my speed. The mileage mentioned above is in the "tow" mode.
My son also has a F-350 with considerably more mileage, tows about the same weight, and he consistently runs in the 12-13 miles a gallon range in the "tow" mode.
This is such a safe truck, I can put up with the lack of gas mileage. I had to do a sudden (interstate) stop over the weekend, and the truck/trailer handled it very very well!
My 08 has a tow/haul selector on the end of the transmission shifter. I leave it in that mode when I am towing and still run through all the gears. If I deselect it and go into OD, I find I must use more accelerator to maintain my speed, plus I don't have the down hill braking that the engine seems to give me in the tow/haul mode. My RPMs or turbo readings do not change from one to the other, but going up even a slight grade, the transmission will start looking for gears in OD. So, I think driving in OD while towing is probably a wash.
I do not understand exactly how the transmission works, but even though you run through all of the gears, it feels more responsive and powerful in the Haul/Tow mode as opposed to OD.
Originally Posted by kimminau2
I believe 1 of the features of tow/haul is that it firms up the shifts, which is why it may feel more responsive and powerful.
