'98 Expedition -six OBD codes
My truck started idling funny. Check engine light came on, I got the codes-p0171, p0174. I changed the MAF then I got p0113 so I changed the IAT. Truck still idling funny. Then I got slammed with 6 codes - p0136 po156 p1131 p1151 p0171 p0174. Anybody have anything?
All,
I had the same problem. Erratic idle and codes P0171 and P0174. Found that the intake manifold vacuum hose conection on the very back of the engine was deteriorated and leaking. You could hear it hissing. I also found that another vacuum hose connection coming from the same PCV valve on the right side of the engine was so deteriorated and flemsy that the vacuum suction was causing it to colapse together and constrict air flow. Check all your vacuum hose connections and I'm pretty sure you'll find your problem. Good Luuck!
oojbearoo
General Automotive Discussion
03-01-2006 12:45 PM
BltFordTough
1983 - 2012 Ranger & B-Series
20
11-03-2005 07:18 PM
