Shifter Linkage
Old 09-23-2007, 06:13 PM
Dustin1690's Avatar
Dustin1690
Dustin1690 is offline
Shifter Linkage
Okay guys i need some quick help i bought my 1993 F150 (in sig) in November of 2006 ever since i even test drove it and got it.. It seems to have sloppy shifter linkage like its hard to put into gear you have to pull hard its not smooth
shifting into a any gear how would i go about fixing this or tightening something to make it shift easily in gear and have tight linkage and feedback is appreciated
Old 09-24-2007, 04:04 AM
kcb37's Avatar
kcb37
kcb37 is offline
Look at everything that has two pieces connected, make sure the bushing/bolt (whatever) are good, and allow the moving parts to do so freely. You may need to take them apart and clean/lubricate them.
Old 09-24-2007, 08:18 AM
Musclestang's Avatar
Musclestang
Musclestang is offline
replace the cable from under the steering column .... to the trans . If you dont .... you will break the shifter tube in the column soon ..... pain in the a when that breaks trust me .
Ok now after you replace the cable .... you have to adjust the new cable .
Keep messing with different places until you can get that joker into drive , and park ....
Old 09-24-2007, 10:25 AM
matt12's Avatar
matt12
matt12 is offline
Check the bracket on the frame just to the left of the trans where the linkage goes mine did the same thing and then just snapped one day while i was heading out ( that will really **** you off) I fabricated a new bracket lined the hole with some 1/4 Teflon it has worked great since good luck
Old 09-24-2007, 05:32 PM
Dustin1690's Avatar
Dustin1690
Yeah well i sure get down and fix it now i dont want it to snap dam thing its not that hard to get into park or drive but definetely not as smooth as some trucks
Aaron-71
40
09-15-2021 08:10 PM
bopfly
05-16-2016 09:26 AM
CrappyPappy
05-04-2016 04:58 PM
F-WhiteThunder
Escape & Escape Hybrid
09-17-2015 07:26 AM
SonofaFord
06-05-2011 04:04 PM
Quick Reply: Shifter Linkage
