Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-23-2007, 05:07 PM
grelsner96 grelsner96 is offline
Garage is empty, add now
grelsner96 is starting off with a positive reputation.
how to do home "cool" air intake?
I have 1996 5.0 f150 xlt..so most everthing in the engine that would change anytihng about air intake is stock. So, I have no idea how to make one of these like I see in the pictures. It the black plastic ones that come out and make a wide rrectangle at the end
__________________
1996 f150 5.0L v8 4x4 shortbed reg cab w 2.25"duels
  #2 (permalink)
Old 09-24-2007, 09:48 AM
chrono4's Avatar
chrono4 chrono4 is offline
chrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to allchrono4 is a name known to all
You want to make a cool air intake? You just have to take all the fittings and related pipe and through the most direct route, put the inake of the system in cool air. This can be up in the grill area, or out the hood, or under the bumper ect.... And "duels" is spelled duals.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
STGs MinionsTechnical Advisor
  #3 (permalink)
Old 09-29-2007, 10:05 AM
blue beast's Avatar
blue beast blue beast is offline
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
I challenge you to a internet duel!!! Touche!!! I made a simple one on my ranger, I just ran some dryer duct from the lower rad opening where air pressure is high and cold I ran the duct from there then down (so water would collect at the low point with a drain hole) then up to the area behind the head light about four inches from the stock intake air horn!! I put a piece of dump truck tarp(big screen basically, works good for radiator protector too wide open mesh with thick diameter material to resist rocks and bugs) It dumps some cold air right where it needs but since it isn't directly connected the road dirt sticks to the bottom of the hood mostly, I can see it is working because the amount of dirt that is sticking to the hood so that tells me high pressure air is going to that area!!
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
Tags
38, 429, 79, air, build, cold, cool, dryer, duct, f150, f350, ford, intake, intakes, make, truck, vt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
