Parking Brake Cable Substitutions
I have an interesting problem. I have a 1971 F250 2WD with a 360 and a C6.
The parking brake cables on my truck are rather old and I purchased the front cable and two back cables. When I got underneath the truck I found that the cables did not match what is there at the momne.t
The front cable that I was given had a ball at the end instead of a threaded screw for adjusting as was underneath the truck. I did some checking and indeed, I was given the correct cable but sometime in the previous lifetime of the truck, the lever to which the cable is connected was removed. Additionally, the threaded end of the existing cable has a hole in the end for the tesioning spring.
So, at the moment, I am pursuing two different paths. One, I'm looking for a replacement lever assembly so I can use the stock cable. Junk yards up here in New England do not have any pickup trucks this old, so any suggestions where I can find it would be appreciated. And at the same time, I would like to figure out what kind of truck donated the cable that is currently underneath my truck.
Now, for the second issue, is that the rear parking brake cables are not the ones that I was given. I have a heavy duty dana rear axel (60 series with 3 inch wide brake shoes). The collar of the old brake cable that snugs up to the backing plate so that the cable enters the brakes at a 90 degree angle while the new cables have a collar so that the cable enters the backing plate at a 45 degree angle. So, where can I find the correct cables or should I go to the standard brakes and get rid of the heavy duty brakes.
Thanks for any help.
-David Glaser
-David Glaser
Tim,
Regarding the rear brake cables, the cables that are currently installed enter the backing plate at a right angle. That is, parallel to the axel tube. However, the new cables that I bought want to enter the backing plate at an angle. I bought the cables via mail order and the catalog did not list two different kinds of brake cables. So I'm wondering why the difference.
Originally Posted by dhglaser
Tim,
Tim
Try to get hold of a Chiltons book with cable routing pics. I have a small chilton book that shows four pics. The only one with side lever is F100-F150-F250LD. The F250-350 2WD HD has its own pic, but I can't tell with regards to entering the backing plate. Like I said, try to get better pic as I think you may have a combination of some kind because of changeover. There are differences in 2WD and 4WD also.
Ooops, I just realized the LD means light duty.
Merlynr, my F250 is a Camper Special so I guess it is heavy duty. The picture that you saw, did it show the use of an oval equalizer instead of the side lever?
More on my Saga!
I removed the drums from the rear axel and removed the old parking brake cables. The backing plates have a square slot for the cable, not a round hole. The fitting that went up against the backing plate allowed the cable to enter through the plate at an angle and align up with the parking brake level. I tried to use a light duty cable but the retainer on the fitting did not hold the cable snugly and there was some binding of the cable with the fitting that went through the backing plate. So this solution was not working very well.
So, I decided to do things the Ford way and use a cable with an angled fitting. I was not been able to find a supplier for new rear cables. However, I went to a local chain/wire rope shop and they are fabricating a new set of parking brake cables for me with the angled fitting and super-duper cables/housings that are guaranteed not to stick and last forever. It will not be cheap but I'm happy with the solution. The only down side is that the connectors on both ends of the cables are slightly larger than stock so I will have to enlarge the holes in the frame cross member and in the brake backing plate.
Additionally, 390428cjt provided me with a very nicely finished parking brake lever (that goes underneath the truck).
So now I'm back to the original design.
-David
-David
on
I believe what you found under your truck was the way the C/S was originally built at the factory. I believe they used the (heavy duty) "Bendix brakes" as a part of the options package that made it a C/S. I'd bet that there never was a parking brake lever, return spring or equalizer rod - at least until you installed them (if that's what you did).
My 1970 is set up the same way, and I'm having a deuce of a time finding the correct front parking brake cable for it.
I do not believe you were provided with the correct cable.
F250's of this vintage did not come with 12" x 3" brakes, a previous owner swapped parts. 1967/79 F350's have 12" x 3" brakes.
Go to www.helmarparts.com and poke around for a substitution brake cable. They are of good quality and were inexpensive a couple of years ago.
Shadow351
1997 - 2003 F150
03-15-2016 05:55 PM
TANDAMAN
06-08-2014 12:40 PM
JMattyAK
02-10-2011 05:36 PM
Danny Stroup
24
11-14-2010 01:01 PM
