K & N filter survey
Originally Posted by RÖENTGEEP
Have any of you used this filter?:
http://www.volantpowercore.com/powercore_filter_detail.asp?ID=4
I installed my 6637 yesterday, (Sunday). I love the sound I'm hearing. It also sounds like the turbo is spooling quicker. I don't have gauges, but I think they're next. Unless I decide to do the 10k, 14.7k, or 15.6k.
Is it ok to do this mod without gauges, or should I wait and get the gauges first? I tow a 24-foot travel trailer and am concerned with 10k etc. that EGTs may get out of hand and I wouldn't know it until it's too late.
I agree. His way is easy to switch. I still have the old 10K on mine but I have the TW and I am told the 10K is unnecessary on some of the burns. I will disconnect and test run then try the c00n way to verify the difference soon. I have others I need to post first but I have been traveling too much.
Originally Posted by c00nhunterjoe
if you do the mod myway, its a quick change to go stock for when you tow and then back to "ressisted" when done
I'll cut the wire (blue with red stripe? I'll double-check my notes.) and add the connectors so she's ready to accept the "kits" I'm building. If I have enough resistors to do what I want, I should end up with "kits" for:
4.7k (one 4.7k)
5.6k (one 5.6k)
9.4k (two 4.7k)
10k (one 10k)
10.3k (one 4.7k and one 5.6k)
11.2k (two 5.6k)
15.9k (one 4.7k and two 5.6k)
20.6k (two 4.7k and two 5.6k)
There are other combinations, but it sounds like getting above 20k is counterproductive.
I don't have the knowledge like you guys, to take any readings, so my results would be from the "seat-of-the-pants" computer I take everywhere with me. How would I test each "kit" after it is installed? These "kits" would be installed on the truck in my signature.
