Need Ignition switch diagram for 1992 F150 - Ford Truck Enthusiasts Forums
Old 09-23-2007, 02:47 AM
toddrivers toddrivers is offline
toddrivers is starting off with a positive reputation.
I am installing a crimestopper keyless entry with remote start on my 1992 F150 2wd 302cid. Need wire color codes for Battery, Starter crank, accessory, tach, Fuel pump ECU. I also need to identify neg horn trigger and dome light circuit + or -.
Thanks for any help on this.
Old 09-23-2007, 08:56 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Here is some 1992 links, it they do not cover what you need post back.
http://i54.photobucket.com/albums/g91/subford/Electrical/Ignition/1992IgnSw.gif
http://i54.photobucket.com/albums/g91/subford/Electrical/Ignition/1992IgnitionSwitch.gif
http://i54.photobucket.com/albums/g9...992Fuelsel.gif
Old 09-23-2007, 09:11 AM
Thanks for the links - looks like these may solve my problem.
Toddrivers
Engine swag to 12v 1992f150Hunter 1987 - 1996 F150 & Larger F-Series Trucks 12 02-11-2015 08:55 PM
1992 ford f150 billy k 1987 - 1996 F150 & Larger F-Series Trucks 5 06-17-2014 03:12 PM
Offset rims for 1992 ford f150 1992FordF150Custom 1987 - 1996 F150 & Larger F-Series Trucks 1 10-07-2011 04:22 AM
1992 ranger buket seats fitting in a 1991 f-150 Justin Todd Trapp 1987 - 1996 F150 & Larger F-Series Trucks 5 09-08-2011 04:06 AM
1991 & 1992 F-150 Truck Transmission KenDeGreat 1987 - 1996 F150 & Larger F-Series Trucks 8 12-07-2009 10:38 PM
Tags
1992, 92, 95, diagram, diagrams, f150, f250, ford, ignition, lock, schematic, schematics, switch, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
