390 Oil Filter housing - Ford Truck Enthusiasts Forums
Old 05-02-2002, 06:20 PM
DutchmanAZ DutchmanAZ is offline
DutchmanAZ is starting off with a positive reputation.
I ran into a problem when trying to bolt my old oil filter housing
on my new 390 block...darn thing won't fit. Mine is a lot narrower
than what the block seems to require. It came off of a 360 out of my
76 F150 4x4. Are there different housings available?
Thanks!
DutchmanAZ
pilot bushings!
Old 05-02-2002, 07:49 PM
DrFord DrFord is offline
DrFord is starting off with a positive reputation.
yes there is more than one kind. I have a 63 and a 74 390. they each have different oil filter adapters. I don't know when the change was made though.
Old 05-04-2002, 11:47 AM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Dutch, I've seen five differant styles of filter adapters on FEs from the factory, but have always found them to be interchangeable, same pattern on every block. What year block do you have and what kind of filter adapter are you trying to put on ? Most pickup trucks have a n adapter that holds the oil filter up and staight out sideways. If the one your trying to install seems narrow, is it 90* turned from where it needs to be ?.......DF
Old 05-04-2002, 01:15 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
numberDummy - need help DutchmanAZ 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-28-2016 08:50 PM
09 FX4 oil filter relocation mreverest72 2009 - 2014 F150 5 12-27-2015 09:00 PM
390 install Paddrick Smith 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-27-2015 10:43 PM
1973 - 1979 Ford Tailgate wanted DutchmanAZ WTB - Parts & other 7 11-16-2015 08:02 AM
390????? 1970Custom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 31 08-03-2004 09:51 PM
Tags
1972, 390, 74, adapter, bolt, bracket, fe, filter, ford, housing, install, mount, oil, position, sizes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
