534? - Ford Truck Enthusiasts Forums
534?
Old 03-27-2001, 10:36 PM
tomk89xlt tomk89xlt is offline
tomk89xlt is starting off with a positive reputation.
534?
A friend was trying to tell me that Ford made a 534 cid block that was put into 72-81 trucks. any one ever heard of this?
Old 03-27-2001, 10:58 PM
ecarter50 ecarter50 is offline
ecarter50 is starting off with a positive reputation.
534?
the 475,477,534 are for large trucks not pickups
Old 03-28-2001, 12:38 AM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
534?
Technically the 534 goes all the way back to 64. We have one in a 1964 C-600 Tilt cab Fire Truck. Even has a 5 speed transmission. It is true that they were only reserved for the large trucks. They also had a diesel for 66, but that's another story.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old 03-29-2001, 02:24 PM
Kenny's Avatar
Kenny Kenny is offline
Kenny is gaining momentum as a positive member of FTE.Kenny is gaining momentum as a positive member of FTE.
534?
Hi, The 401, 477, and 534 used in big trucks were refered to as "Super-Duty" engines. I don't know when they were first made available for the big trucks, but I know they had them back in 1959 in the F-850 to F-1100. There were also "Heavy duty" engines for the F-500 to F-800. They were the 292 HD, 302 HD, and 332 HD. I know that the 292 was a Y-block, but what about the 302 and 332? Were these Heavy duty engines part of the FE family? Just curious. Thanks,
Kenny
Old 03-29-2001, 06:57 PM
534?
I don't know about the 332, but there was a 330 MD and a 330 HD in use in 64-66 that I am aware of. We also have a 1964 C-550 that has a 330 with a 5 speed transmission. (4 spd w/ OD) And it is of the tilt cab variety as well. The 330 is a part of the FE engine family, but it is not really widely discussed because it was such a short stroke engine. And only used in the heavier trucks.
Can see both below.
Old 03-30-2001, 01:06 AM
Kenny's Avatar
534?
Thanks, I appreciate the reply. I was just curious thats all. I always wondered what they were (302/332), and when I saw that the first engine listed in this conference was a 332, it made me wonder if it was the same engine.
Kenny
Old 03-30-2001, 01:27 AM
534?
I had noticed that the earlier trucks (larger) had a 302. I figured it was the 302 windsor, but I guess not.....
I'd still like to pull a 534 and put it in my 65 Ford F-100. Talk about a scream machine.
Can see both below.
Old 03-30-2001, 12:15 PM
Kenny's Avatar
534?
I often thought about that. That would be awesome in a pickup! My dad used to drive a 1960 single axle F-1100 with the 534, 5 speed, and 2 speed rear. He said even pulling a full load that thing was still a real "flying machine". My '59 shop manual shows the 302/332 as having the same block. They have the distributor up front. You're right. It seems like nobody mentions these engines anywhere. Maybe someday.
Kenny
Old 03-30-2001, 06:11 PM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
534?
The 332 is an FE Block. We have one in a grain truck back home. The truck is a C-750 cab over. Grandpa has that thing so souped up that it will actually spin the big duals in the back when you stomp it in second. The valve covers say lincoln.
Old 03-30-2001, 08:16 PM
Kenny's Avatar
534?
Thank you! I really appreciate that info.
Kenny
Old 08-21-2001, 01:19 AM
rdnck4x4 rdnck4x4 is offline
rdnck4x4 is starting off with a positive reputation.
534?
would it be possible to swap on of them motors into a standard pickup?or would there be major fenderwell modifications required.think about the possiblities though,mr 502 chevy would crap himself...haha....blue oval beef at it's finest
Old 08-21-2001, 10:17 AM
6t6merc 6t6merc is offline
6t6merc is gaining momentum as a positive member of FTE.6t6merc is gaining momentum as a positive member of FTE.
534?
My Chilton's says the 534 makes 266 hp at 3200. Not really a screamer. The heavy trucks equipped with this engine had a very cool "Super Duty" chrome script on the sides of the hood.
Eric
Old 08-21-2001, 12:32 PM
534?
what are the torque figures?
Old 08-21-2001, 03:48 PM
ksd ksd is offline
ksd is starting off with a positive reputation.
534?
None of those engines are bolt-in replacements in light duty trucks, and none are "FE" engines. They are FT blocks, and differ somewhat from the FE castings. The most obvious external clue that you have a FT block as opposed to a FE are the engine mount holes. If each is drilled for 4 bolts, you have a FT block. It will not fit FE engine mounts, which used either 2 bolts (58-64) or three bolts (65-76) on each side. The FT blocks were also considerably heavier and used higher strength alloys. While some parts interchange between the FE and FT blocks, many do not.
The FT engines were made for massive torque, low horsepower, and reliability under extreme conditions that light duty trucks and cars never see. Their extra weight, poor throttle response, and low revving characteristics, combined with the need to make significant modifications to accomodate them, mean that they make very poor choices for anything other than the heavy duty commercial vehicles they were designed for.
ksd
69 F100 Explorer lwb 2wd FE 360 C6. WANTED: straight/clean styleside long box w/aux fuel tank for 67-69 F series.
Old 08-21-2001, 03:59 PM
BB's Avatar
BB BB is offline
BB is starting off with a positive reputation.
534?
[font size="1" color="#FF0000"]LAST EDITED ON 21-Aug-01 AT 04:04 PM (EST)[/font][p]Actually they are not even FT blocks but unique big blocks all by themselves. Their closest relative is the MEL series in design but it stops right there. The Super Duty or SD motors use a plank head but the block deck is angled even more than the MEL is. They also have a built-in oil cooler on the right side of the block. These engines are massive, I donít think you could fit one in a pickup.
1966 T850 Super Duty 534 Engine Paint Scheme Harley48 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-08-2015 04:10 PM
1974 534 ci thesixd Large Truck 2 12-10-2013 05:53 AM
534 engine help SuperBerry111 401, 477, & 534 SD Engines 2 11-03-2013 10:30 PM
534 torque smoke n tires 401, 477, & 534 SD Engines 20 11-24-2004 07:53 PM
Try out these links 68torino 401, 477, & 534 SD Engines 0 04-11-2004 08:40 PM
Tags
500cid, 534, big, block, bore, cid, engine, f1000, ford, fords, mel, stroke, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
