I have the heavy duty trailer tow package as well, and the cooler has seven rows.
I did notice however that in addition to having only seven rows, the unit is about 18 inches long.
this is larger than some I've seen similarly that were 8"-12 " wide.
so I'm thinking the width of the unit is making up for an 11 row cooler that is not as wide as this one. also, being a wider/longer design keeps the fluid in the airstream just a bit longer allowing for more disipation of heat.
however, if in fact we should have 11 rows, I'll be next in line to get mine.
I'm hoping this it the case that the referenced PDF spec sheet was pre-production, and the cooler is now wider then before.
Without starting another thread, what is the difference in the radiators? Per the PDF spec sheet again, the 536 Heavy Duty tow has a "Radiator Upgrade". Anyone happen to know what the upgrade is?
Most of the literature has a disclaimer that parts may change at any time. The 2007/2008 were much cheaper than the previous years. They had to cut costs somewhere and with the 6 speed tranny, they may have not needed that large of cooler, not sure.
just got our 08, it's a huge cooler, much bigger then my old 5.4 f-150 with the tow package, i like how wide it is, should cool the fluid off real nice. I'd say it's more then enough.
Looks to be about 22" long and for a Heavy tow 7row non-heavy 5row. And it's a stacked plate type cooler.
__________________
2002 Expedition XLT (2wd with 4R100 auto) with 146k...traded on an 2008 Expedition XLT (2wd with 6R75 auto)Heavy tow-package, DVD,18"Chrome Clad wheels,Leather and ScanGauge II.
You are correct. They go by the finned areas...your pic has 7 finned areas.
__________________
Oh, I am so glad to find this thread. I had a heck of a time w/ my dealer who told me the car could tow up to 9200lbs but the manual said 6000 unless I had the tow package. When digging into it I found my truck only had the standard package. Long story short I had them upgrade the radiator and transmission cooler on them. Then when I was looking at it I thought they never actually did the work because it was only a 7 row cooler and the PDF did say 11 for the upgrade. Needless to say my head was a little hot until I found this thread and it looks like I am all set there.
Anyway I was left me with the electrical work to do.
I have a late model 2008 Expedition - Built in June 2008
I came across this thread and have an update for those concerned. My Expedition has the 536 heavy duty towing package, but the transmission cooler is the 5 row ........ not 7 row.
I went back to the dealership and checked two other Expeditions with the heavy duty towing package, as well as two navigators and they all have the 5 row transmission cooler also.
I am assumiming Ford did not see the need for the larger 7 row unit???????
