Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-21-2007, 04:03 PM
Fat_Batster Fat_Batster is offline
Fat_Batster is starting off with a positive reputation.
This is how to repair the "non-serviceable" plug on your HPOP
This is how to repair the plug that is on the bottom of the HPOP (the plug that you have to remove the HPOP to get to). This plug is listed in the service manual as "non-serviceable"/"do not remove".
After tracking down the leak on my HPOP, I found it to be the plug on the bottom that is not serviced in any of the kits that I read about. After hearing the horror stories about people trying to repair this leak only to have the threads strip out or the HPOP not build pressure afterwards, I made a trip to the local International dealer. I was able to speak with a very knowledgable service guy that informed me that there is indeed a service kit for this problem. He stated that the DT466 I-6 engine uses a very similar HPOP and there was actually a recall that addressed this issue. The recall was only for the I-6 though so that is why many people wouldn't know about it. He took me back and showed me how to fix the problem and while I was there I picked up the repair kit that has the instructions,new plug, o-ring, and loctite (the kit contains extra parts that aren't used on the 7.3 HPOP). The part # for this kit is 1842906C92. I would scan the instructions but I do not have a scanner, sorry. The instructions basically state that the plug should be heated before removal whch should reduce the chances of stripping out the threads. Also, before any plug is removed, the HPOP should be positioned straight up and down with the machined face down and the snap ring end up so that the "ferry plug check ball" is not disturbed. I hope this helps alot of people that don't want to/can't pony up the money for a new pump.
  #2 (permalink)
Old 09-21-2007, 04:13 PM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of ron's power stroke has much to be proud of
GREAT TIP... thanks...and welcome to FTE..
__________________
Early 99 7.3 F350 auto,GTP38R BB turbo, AFE stage2, 5" strait pipe, DP live tuned-PMT1 soon to happen, 140 IDM, Terminator Modified 17* HPOP , DIY fuel bowl delete, DI Regulated Return fuel feeding Ryan Casserly's SS stage 2's moded EPD process 100% over nozzles http://fullforcediesel.com/
exploded view of a 7,3 << more pix of my truck
  #3 (permalink)
Old 09-21-2007, 04:54 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
Maximus Overdrive
1999 Ford F-250
bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of bdrummonds has much to be proud of
Very good info to have, thank you. WELCOME TO FTE.
__________________
Brandon
PAA MEMBER # 7.3, 99.5 CC,4X4,SB, leveled,live tuned by Jody,1.15 van turbo w ATS housing,6.0 IC,AFE big boost filter, Petes Armour, FASS/DFA fuel system,fuel bowl delete,black MBRP stacks, 02 headlights,F650 dash, and a bunch other stuff that wont fit in my sig. 293K and counting.
  #4 (permalink)
Old 09-21-2007, 06:09 PM
dcara dcara is offline
dcara is starting off with a positive reputation.
The bit about heating the plug to keep it from striping I would like to understand better. When I was a teenager I worked a few months at a truck tire shop and we would often heat the nuts on a big wheel to get them off since the heat would make the nut expand and hence be slightly bigger than the stud.
So if you heated the plug as mentioned above then wouldn't it expand inside its threaded hole and become more difficult to remove?
__________________
Doug
early 99F250 PSD 7.3L 4x4
Heavy Duty TC, ISSPRO gauges on the A-Pillar, AC improvement mod, True Cool. CAT delete, Harpoon and Hutch mods with prefilter
  #5 (permalink)
Old 09-21-2007, 06:24 PM
lhud lhud is offline
lhud is starting off with a positive reputation.
One theory is that when the plug is heated it in fact does expand and at the same time will break any corrosion bond between the thread surfaces.
When it has cooled down somewhat, it is easy to remove as mentioned above without damaging the threads.
  #6 (permalink)
Old 09-21-2007, 08:00 PM
piotrsko's Avatar
piotrsko piotrsko is offline
piotrsko is starting off with a positive reputation.
I'm guessing that the heat is to break loose the locktight which would also save the threads
__________________
2000 PSD CC LOOOOOng bed 6spd for the next 20 years (or more) AKA Oklahoma stretch limo
86/87/88 Ranger 2.9 XLT (same truck long story) 88 ranger 2.9 4X4 lifted 20 some inches (parts car)
2003 FOCUS 2.3 5 spd (her car)
4 lines all 2pt.
  #7 (permalink)
Old 09-21-2007, 10:40 PM
JoeTrotter's Avatar
JoeTrotter JoeTrotter is offline
JoeTrotter is starting off with a positive reputation.
Great write-up! Props given.
  #8 (permalink)
Old 09-21-2007, 10:42 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
That is truly an excellent first post. Again, welcome aboard.
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #9 (permalink)
Old 09-22-2007, 12:24 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
2002 Ford F-350
PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold PowerstrokeJunkie is a splendid one to behold
Very nice first post. Reputation points given Welcome to FTE. I see you being a big asset to this place in the future.
__________________
2002 F-350 Thats been nothing but a waste of time and alot of money!
  #10 (permalink)
Old 09-24-2007, 10:34 AM
Thanks everybody!
To answer the question about the heat, in the instructions it was stated that the heat breaks down the loctite thus allowing easier plug removal (like piotrsko said). Even if your threads are a little mangled, I would still attempt this repair because the replacement plug has about 1/8" more threads on it than the original plug and this will allow the plug to engage threads that were previously unused. I actually performed this repair over the weekend and so far there are no leaks. However it is taking about twice as long to start in the morning than it did before I did the repair. I am going to hope that this is due to there being air in the lines but I really don't think that there is because even upon the first engine start after the repair was completed there was never a stumble, hiccup, pop, wheeze, miss or anything and the trucks runs smooth. Any suggestions?
  #11 (permalink)
Old 09-24-2007, 11:06 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II MLCRI$I$ II is offline
got BioD?
MLCRI$I$ II is starting off with a positive reputation.
Welcome - Rep points coming!
Welcome aboard. This tip goes in my 7.3 maintenance binder! You get some rep points from me too .
Ernie .
  #12 (permalink)
Old 09-24-2007, 11:35 AM
F250_'s Avatar
F250_ F250_ is online now
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Excellent contribution right from the start. Thanks, and WELCOME to FTE!!!
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #13 (permalink)
Old 09-25-2007, 10:22 AM
Just an update to my question about my extended cranking times, I put a few more miles on her and everything is back to normal now.
  #14 (permalink)
Old 10-16-2007, 03:40 PM
Rick2001 Rick2001 is offline
Rick2001 is starting off with a positive reputation.
Has anyone else done this repair?
I take it the part number is for a kit from International.
__________________
2001 F350, 4x4 off road, 7.3, DP Tunes 40,60,80, Turbo Master Waste Gate, Auto w/6.0 cooler, CC, LB, 3.73's, Royal Purple in all but the engine, 285 BFG AT's, Curtis pop-hitch, 6637, Zoo-Dad, stock downpipe then 4" Magnaflow (free), Auotmeter cubby mount gauges, CB, Sirrius, Bilstein HD shocks.
  #15 (permalink)
Old 03-29-2009, 06:08 PM
kawa's Avatar
kawa kawa is offline
kawa has a good reputation on FTE. kawa has a good reputation on FTE.
Repair of "Non-Serviceable Plug on HPOP
Old post with great info for HPOP leak repair.
Fat_Batster ******** type="text/javascript"> vbmenu_register("postmenu_5149349", true); *********>
After tracking down the leak on my HPOP, I found it to be the plug on the bottom that is not serviced in any of the kits that I read about. After hearing the horror stories about people trying to repair this leak only to have the threads strip out or the HPOP not build pressure afterwards, I made a trip to the local International dealer. I was able to speak with a very knowledgeable service guy that informed me that there is indeed a service kit for this problem. He stated that the DT466 I-6 engine uses a very similar HPOP and there was actually a recall that addressed this issue. The recall was only for the I-6 though so that is why many people wouldn't know about it. He took me back and showed me how to fix the problem and while I was there I picked up the repair kit that has the instructions,new plug, o-ring, and loctite (the kit contains extra parts that aren't used on the 7.3 HPOP). The part # for this kit is 1842906C92. I would scan the instructions but I do not have a scanner, sorry. The instructions basically state that the plug should be heated before removal which should reduce the chances of stripping out the threads. Also, before any plug is removed, the HPOP should be positioned straight up and down with the machined face down and the snap ring end up so that the "ferry plug check ball" is not disturbed. I hope this helps alot of people that don't want to/can't pony up the money for a new pump.
Further into this thread it was"assumed" that the heating was to loosen the Loctite. Fat Baster further stated that the repair/replacement plug is
"Over sized" to compensate for any thread loss.
Rog
__________________
1997 Red 4X2 CC S/B-3" DP- No Kitty-6637
Cooling Sys. Filter-7 Gauges-6 Pos.PHP Chip
140V IDM-The "Cure"-CCV Mod w/Filter
1.0 Turbo-No EBP-Detroit Locker/Finned Cover
U. S. Gear Exhaust Brake-Ext. plug for Heater &
Cadillac Battery Water-On board Batt. Charger
Tags
1842906c92 , 2002 , 73l , changed , dt466 , exploded , hpop , instructions , nonserviceable , oring , plug , powerstroke , replace , replacement , serviceable , view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
