Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 07-27-2009, 01:02 PM
fordprobe1 fordprobe1 is offline
fordprobe1 is starting off with a positive reputation.
I have been reading this post and I am trying to fix this plug. When you refer to the machined end face down and the snapring end up, can you clarify that exact position?
Thanks
  #17 (permalink)
Old 07-27-2009, 01:38 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is online now
Support FTE
PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of PaysonPSD has much to be proud of
This is a pic of the rear of the HPOP.
You can see the snap ring holding the rear plate.
The other end is the "machined face". The end
that faces the front cover where the drive gear mounts.
  #18 (permalink)
Old 07-27-2009, 01:45 PM
HeatStroked's Avatar
HeatStroked HeatStroked is offline
HeatStroked is gaining momentum as a positive member of FTE. HeatStroked is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Rick2001 View Post
Has anyone else done this repair?
I take it the part number is for a kit from International.
I did it on a 2002 about a year ago. No problems since.
I believe KCM Diesel sells the correct O ring so you don't have to buy the IH kit.
  #19 (permalink)
Old 07-27-2009, 08:02 PM
Thanks Payson,
So, if I put the hpop in a vice in the exact position as pictured with the snap ring up, I can remove that plug with no problems?
  #20 (permalink)
Old 07-27-2009, 11:38 PM
PaysonPSD's Avatar
Support FTE
Quote:
Originally Posted by fordprobe1 View Post
Thanks Payson,
As long as you follow the instructions you should be OK. Be careful you do not strip out the threads
  #21 (permalink)
Old 07-27-2009, 11:41 PM
PaysonPSD's Avatar
Support FTE
Thanks Payson,
As long as you follow the instructions and don't strip the threads or loose the check ball.
Edit: Double post - oops.
  #22 (permalink)
Old 07-27-2009, 11:47 PM
Tenn01PSD350's Avatar
Tenn01PSD350 Tenn01PSD350 is offline
for now.....
Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold Tenn01PSD350 is a splendid one to behold
Hmmm, this reminds me, Ron's last activity here 07/15/09. I hope all is well.
__________________
Mike
Silver truck with a hairdryer and sticks. A lot of other less expensive chit too which adds up to expensive.
  #23 (permalink)
Old 07-30-2009, 05:29 AM
Okay guys, I bit the bullet and took it all apart. I have the hpop off and I am ready to rework that "unserviceable Plug". I was told there was no way to put new o-rings in that plug while the hpop is still in the truck because (when the plug is removed) the ball will fall out in the position that it is in the truck. Once the ball falls out, no guarantees! Can anyone tell me the torque specs on the bolts that hold the oil resevoir down. I will be replacing all of the o-rings in the hpop and fuel lines. Do you recommend replacing the rubber seal/filter at the base of the oil resevoir. Thanks for all of your help. I have photos for anyone that is attempting this project.
  #24 (permalink)
Old 07-30-2009, 12:53 PM
PaysonPSD's Avatar
Support FTE
Here are instructions (LINK) from DieselSite for installing an Adrenaline HPOP. Torque specs included for HPOP reservoir and mounting bolts. 18 lb/ft for both.
Drive gear is 95 lb/ft but when I tried to get it to that torque the engine would turn over. Bob Riley at Dieselsite said if that happens it is tight enough. The rotation of the gear is such that it won't loosen.
  #25 (permalink)
Old 07-31-2009, 11:12 PM
Macamon's Avatar
Macamon Macamon is offline
2000 Ford F-250
Macamon is starting off with a positive reputation.
Always right there with the answer, you rock peyton
  #26 (permalink)
Old 08-01-2009, 01:10 AM
firedewd's Avatar
firedewd firedewd is offline
firedewd is starting off with a positive reputation.
Good update, I was planning on checking mine this week. Got a few drips showing up.
. Thanks!
__________________
They told me it's not rocket surgery!
2000 F250 CC SB PS
Wilderness 5th Wheel
Starcraft Tent Trailer
The sooner I fall behind,
the more time I have to catch up!
  #27 (permalink)
Old 08-03-2009, 02:03 PM
Put the truck back together this weekend, changed the oil and all of the filters. Also changed all of the o-rings in the fuel bowl (very easy with it out of the truck) and fuel lines and oil lines. No leaks up front by the hpop- great. However, I still have a very small drip underneath the rear side of the block - Murphy is at work again. The oil leak seems to dark to be the fresh oil that I just put in. ???
Thanks all for your help - the major oil leak is fixed, so at least I can drive it. You guys are great thanks alot. If anyone needs any help on this hpop project - I can assist.
Who do I ask about a power seat not working?
Let me know
Mark
  #28 (permalink)
Old 08-03-2009, 05:22 PM
PaysonPSD's Avatar
Support FTE
Let me know
Mark
Glad you had a successful HPOP R&R.
That dark oil leak may be residual from the leak you just fixed. Let's hope so.
As far as the seat start with the fuses. Then the switches. If you have to, remove the seat and wire it up to some 12 volt power and you can see what's going on.
  #29 (permalink)
Old 10-27-2009, 01:05 AM
londonphish londonphish is offline
londonphish is starting off with a positive reputation.
Send Photos
Yes could you please send some photos as I have this problem and I want to fix it ASAP.
Tim
  #30 (permalink)
Old 10-27-2009, 01:23 AM
Rockrunner86's Avatar
Rockrunner86 Rockrunner86 is offline
Rockrunner86 is starting off with a positive reputation.
Good info..
Tags
1842906c92 , 2002 , 73l , changed , dt466 , exploded , hpop , instructions , nonserviceable , oring , plug , powerstroke , replace , replacement , serviceable , view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
