What is job of Atlernator Exciter Wire??? - Ford Truck Enthusiasts Forums
Old 09-21-2007, 08:15 AM
e william's Avatar
e william e william is offline
e william is starting off with a positive reputation.
I posted the below ? in wiring forum as well....
Good progress made on wire harness...main pwr. lead to fuse box will hook to the "B" terminal on the regulator...can someone tell me what job the "alternator exciter wire" does ? I dont seem to have a home for it (I have a 12v gen. and external regulator).
Is it possible that this is the trigger for the starter, I have one wire label to starter that goes to the battery side of starter selinoid but need a return from start switch to the other side of selinoid.
All other systems wired and accounted for ...I think!
thanks,Ed
Old 09-21-2007, 09:16 AM
1949f1's Avatar
1949f1 1949f1 is offline
1949f1 is gaining momentum as a positive member of FTE.1949f1 is gaining momentum as a positive member of FTE.
thanks,Ed
put it to a hot side of the switch when the key is in the run position,it will not charge if it don't get 12 volt's to it in the run position.
Old 09-21-2007, 10:44 AM
49fordpickumup's Avatar
49fordpickumup 49fordpickumup is offline
49fordpickumup is gaining momentum as a positive member of FTE.
Alternator
The primer/exciter wire supplies the voltage during start up until the alternator supplies its own exciter to equalize voltages. Once it equalizes it turns out the alt light. If the light doesn't go out the diode in the equalize circuit may be defective.Have a great day,chuck
Old 09-21-2007, 11:16 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
If you don't have an alternator, don't use it!! Hook up your generator just the way it was.
Old 09-21-2007, 01:42 PM
e william's Avatar
I traced the alt. exciter back and it looks like it is on a fuse with the radio acc. and the electric wiper leads on the other side of the fuse...? I'm not going to use it and I'll test the power to the other leads before I remove it from the fuse block as unneeded...or better yet, I'll just terminate it in case I go to an alt. setup in the future.
thanks for the input, Ed
Old 09-22-2007, 12:18 AM
CharlieLed's Avatar
CharlieLed CharlieLed is offline
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
In engineering terms: when a coil of wire is passed through a magnetic field current is induced in the wire. In a generator the magnetic field is produced by permanent magnets; however in an alternator the field is created in coils of wire wrapped around an iron core. The armatures are similar in both setups. As the other Chuck said in an earlier post, the exciter lead must be hot to create the magnetic field otherwise it's just an armature spinning in air.
1978 F100 charging issue Gwencon 1973 - 1979 F-100 & Larger F-Series Trucks 0 04-05-2016 03:32 PM
power to the starter davisrn94 1987 - 1996 F150 & Larger F-Series Trucks 13 05-01-2015 09:33 PM
Starting issue Flip old 6.0L Power Stroke Diesel 2 11-13-2014 08:32 PM
Weird starter issues... Please help BRay09 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 31 06-21-2011 01:14 PM
wiring help 0351mike 1966 - 1977 Early Broncos 3 11-21-2007 12:42 PM
Tags
120v, 2001, 2002, 944, alt, alternator, exciter, excitor, f250, focus, ford, hook, lead, regulator, truck, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
