Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-20-2007, 10:37 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
RAMS Horns!
If anyone wants to see what a set of new ceramic coated Rams Horns looks like on a Y-block....have a look at my Gallery!
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #2 (permalink)
Old 09-20-2007, 11:12 PM
kooper909's Avatar
kooper909 kooper909 is offline
1960 Ford F-100
kooper909 is starting off with a positive reputation.
Real nice. Those ram's horns sure look sweet ...
Myself, I've only got the scratch for one rams' horn. The asymmetry should be a nice conversation starter. But hey, I'll have duals.
__________________
1960 Ford F-100. '57 292, 3 speed. Mild traditional custom daily driver with red scallops and wide whites.
  #3 (permalink)
Old 09-20-2007, 11:26 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Wow, CLASSY. They look great!
kooper, I only have one Rams Horn too.
__________________
1946 1/2 ton with Y-block
1962 Unibody F-100
1990 Ranger 4WD
1954 Model 600 tractor
  #4 (permalink)
Old 09-21-2007, 10:37 PM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
Nice. Is it coated on the inside?
Looks like you got the ECZ-B intake.
I notice that the oil sender in on the back of the oil passage. Any particular reason for that location?
Tell me that's not a Fram oil filter.
__________________
Best regards,
Paul Menten
  #5 (permalink)
Old 09-22-2007, 12:43 AM
HT32BSX115's Avatar
1. Yes they are coated inside and out.
2. ECZ-B yes. I have a 4160 carb. I'm not sure that's going to be the right carb though I'm hoping it might work but I don't expect it to work correctly. I'm probably better off selling it and getting something else...It's a rebuilt marine carb from an OMC 460 stern drive.........suggestions?
3. It's a Baldwin B2......No Frams here! I use Baldwin on the 6.5L diesel, Johndeere/Onan/Yanmar powered mowers/tractors, all the cars, boat etc. If they made one for the airplane I'd use it there too.
4. I put the oil sender in the hole that didn't have a plug in it. I probably won't leave it there though...I'll probably move it it up to the front.
__________________
  #6 (permalink)
Old 09-22-2007, 02:00 AM
46yblock's Avatar
Fram Baaaddd.
I tried to pull out the oil galley plug at the back so I could move the sender from front to back, but couldnt get it to break free. On this new C2AE block I was planning to put the sender at the back but guess what, there wasnt a rear galley hole behind the oil filter, only the boss. Should have drilled and tapped one in but didnt.
__________________
1962 Unibody F-100
1990 Ranger 4WD
  #7 (permalink)
Old 09-22-2007, 02:36 AM
HT32BSX115's Avatar
I don't know where I actually want to put it right now. I have 3 or 4 places I could put it I guess. I also have a remote oil filter mount that came off the OMC 460 that I might usetoo. That'll give me the ability to use a longer filter and put an oil cooler in line too. I have been thinking about using an electric fan and if I do that I know I'll need all the cooling I can get. I will probably shy away from an electric fan though. I lean towards a clutch type fan instead.....they work so much better and when you need to turn a fan no electric motor can match the engine!
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
