Grinding noise while turn left
CHECK YOUR EXHAUST!!!! I spent two months going back and forth to dealership, specialists and all and I discovered what it was by a fluke. I was told front end parts, hubs, brakes, etc.
One day I was showing off the 5" exhaust pipe by putting my foot inside of it. I had about an inch of play from side to side and I heard a clank. I got under there and found out it was one of the exhaust hangers smacking up against a framerail. I made adjustments until I couldn't get any noise when it was shaking side to side. I went for a ride and almost cried when there was no more noise turning left. I would have sworn a paycheck that the grinding noise was coming from that front left wheel/hub area.
Go out and kick the exhaust pipe and swing it side to side. If you hear anything, try to find out where it is and adjust it.
I hope that's all the problem is, because it cost nothing to fix it.
Good Luck!
___________________________________________
"The Land Shark" is an 03 Excursion 4X4 with a 7.3!
Good Luck!
wreckinball
13
08-04-2010 12:10 AM
