Oil cooler cause EGR cooler failure?
My 2004 6.0 PSD is in the shop again. First time they replaced the EGR cooler and EGR valve. Now 1800 miles later they say the oil cooler caused a hole in the EGR cooler and EGR valve failure. Is that possiable or is the service manager trying to avoid the real problem? He also says he has never seen one blow a head gasket.
When I went to get the truck it was covered with standing oil inside and out. They left nuts off the module on the driver side valve cover. Left a bolt out of the intake, and twisted the fuel line closed at the fuel filter housing. I have inspected it four times and always find something missing. Anyone know any real techs around Greenville/Wilson Noth Carolina?
the oil cooler passages that coolant flows through can get restricted and starve the egr cooler for coolant which will cause repeat egr cooler failures. usually when i have a bad egr cooler failure i also find a oil cooler restriction as well.
sorry about the bad service. people like that make my job alot harder than it has to be.
I am still waiting for them to replace the fuel line and intake bolt. Think I will call back today. Just mad they dont care for a $30,000 vehicle any better than they have.
By the way the original problem both times was it was pushing coolant out the degas bottle.
I purchased my delete pipe from Elite Diesel and installed it today. I have better Turbo boost and MPG have risen 2 MPG around town. I left alone the EGR and the Cooler. The Delete pipe blocks off the exaust and removes the restrictor in the Turbo up-pipe. What a nice performance up-grade..Look at there website for more information...
bowti please get back to this if you get a chance i just took my engine oil cooler out when i buy a new one is it the whole assy that the filer units bolt on to or just the piece that sits in the oil there was two bolts in the bottom i removed them but couldnt get the core part off?
Livenamoment,
Contact Matt at Spartan Diesel (a sponsor here) as a tow bill to Hendersonville, NC (or a short drive if the 6.0 is driveable) could save a lot of heartache.
At a very minimum he knows what he is doing and will shoot straight w/ you as to the cause/fix even if you can't make it too him.
Amp
OOPS, my bad, your in G-ville NC, not SC. That's quite a ways further than what I thought after 1st reading. It would still be worth a phone call though. No wonder your having such a hard time finding a good tech. All that alcohol flowing at ECU has probably tainted the water supply down there!
Amp
2006powerstroke90
01-18-2012 06:19 AM
