Winterize 6.0
Winterize 6.0
I live in a very cold climate. Temperatures will reach 50 below this winter. I keep my F250 in a heated garage. It came to me used and is not winterized. Are there block heaters already installed on the engine?
I plan to install oil pan heater and auto trans pan heater.
What oil is good for engine in winter?
Does Ford ok synthetic trans oil?
Thanks.
Thanks.
Thanks.
Thanks.
Here is the link from the 6.0 tech folder to the cord routing (Cord part number at International: Z3500043) if you need to add it.
http://www.forddoctorsdts.com/articl...icle-05-20.php
For cold climates 5W-40 synthetic is the oil of choice, any brand that is at least API CI-4+ rated.
The Torqueshift transmission only uses Mercon SP fluid available from Ford or one of its parts distributors. The Mercon SP is a synthetic fluid.
I would also suggest synthetic fluid in the front axle (rear has it from factory) and transfer case.
Here is a thread from the 6.0 tech folder on winterizing
http://www.ford-trucks.com/forums/24...d-climate.html
You may want to also install a cold blanket front on the grill to control air flow through the radiator.
Thanks.
Thanks.
Goodluck with the new truck
Your profile says you are in Alaska, so unless you bought his truck from another state it should already have the block heater cord installed. Look around behind the bumper on the passenger side by the tow hook and make sure you don't already have it.
Otherwise the guys have you covered pretty well.
Firefighter 1406
10-17-2016 07:35 AM
90pioneer
03-13-2013 02:46 PM
