Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-18-2007, 10:13 PM
cjgeorge32 cjgeorge32 is offline
Garage is empty, add now
cjgeorge32 is starting off with a positive reputation.
Unhappy AdvanceTrac with RSC?
If the AdvanceTrac with RSC is engaged at all times why is there a RSC button on the dash? When does it need to be used?
  #2 (permalink)
Old 09-19-2007, 09:44 AM
ExpyBob ExpyBob is offline
ExpyBob is starting off with a positive reputation.
When you turn it off.
See manual.
__________________
Bob
  #3 (permalink)
Old 09-19-2007, 01:07 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Yeah, when you want the tires to slip, as in peel out, or whatever reason.
  #4 (permalink)
Old 09-19-2007, 01:26 PM
So the button turns it off?
  #5 (permalink)
Old 09-19-2007, 01:35 PM
berry1234's Avatar
Quote:
Yes, otherwise it is always on.
  #6 (permalink)
Old 09-19-2007, 02:30 PM
myexpo02's Avatar
myexpo02 myexpo02 is offline
myexpo02 is starting off with a positive reputation.
So if it is turned off...how well does it peel out on the dry?
  #7 (permalink)
Old 09-19-2007, 02:38 PM
berry1234's Avatar
Quote:
Not that good with new tires. On a turn better.
  #8 (permalink)
Old 09-19-2007, 02:41 PM
myexpo02's Avatar
Quote:
I didn't think it would very do it very well.....but interesting.
  #9 (permalink)
Old 09-20-2007, 10:39 AM
07EXPYEL 07EXPYEL is offline
07EXPYEL is starting off with a positive reputation.
Button operation is covered in the manual. There's a nice functional reference table in the manual that I couldn't copy. You can download the 2007 manual (not the 2008 yet) from the ford fleet site.
http://www.fleet.ford.com/maintenance/owners_manuals/default.asp
AdvanceTrac_ with RSC button and icon functionality
The AdvanceTrac_ with RSC system automatically turns on each time
the engine is started, even if it was turned off when the engine was last
shut down. All functions of the AdvanceTrac_ with RSC (RSC, ESC,
Engine Traction Control, and Brake Traction Control) will be activated at
start up. When the system is left active, the “sliding car” icon in the
reconfigurable telltale (RTT) location in the message center will flash
only when any of the components of the system are affecting the
vehicle’s performance, otherwise the light will remain off. Consequently,
the “sliding car” icon will not be illuminated during most of your normal
driving.
The AdvanceTrac_ with RSC button,
located on the center stack of the
instrument panel, allows the driver
to control certain features of the
below 25 mph (40 km/h). If the
vehicle is below 25 mph (40 km/h), momentarily pressing the
AdvanceTrac_ with RSC button will disable RSC, ESC and Engine
Traction Control and steadily illuminate the “sliding car” icon. Pressing
and holding the AdvanceTrac_ with RSC button for more than five
seconds will further disable the brake portion of the Traction Control
feature and the “sliding car” icon will flash momentarily and then
illuminate steady.
If the vehicle is above 25 mph (40 km/h), momentarily pressing the
AdvanceTrac_ with RSC button will steadily illuminate the “sliding car”
icon, however, the AdvanceTrac_ with RSC system will remain enabled
until the vehicle speed drops below 25 mph. If the vehicle speed
decreases below 25 mph (40 km/h), the system will become deactivated,
but if the vehicle speed subsequently increases to above 25 mph (40 km/h),
the system will again become active. In general, the system will be active
at all times the vehicle speed is above 25 mph (40 km/h).
When in R (Reverse) or in 4L (4x4 Low), ABS and the Traction Control
feature will continue to function, however ESC and RSC are disabled.
All these conditions are normal during AdvanceTrac_ with RSC
operation. Refer to the following table.
Look @ page 262 of the 3rd printing.
  #10 (permalink)
Old 09-20-2007, 07:59 PM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
07 That is very helpful. I have been lurking and getting ready to by one but not having a rear locker scared me as jobsites are a daily occurance and sugar sand isn't fun with electronic traction control but this looks interesting.
Again thanks.
  #11 (permalink)
Old 09-26-2007, 09:58 PM
jackson3000 jackson3000 is offline
jackson3000 is starting off with a positive reputation.
Monte, go with the 4x4 if you spend any time on job sites. It will be worth it
  #12 (permalink)
Old 09-26-2007, 10:48 PM
I've only tried my 4x4 once and it seemed to provide excellent traction in loose dirt. I've been stuck before with my old rwd van with a locker wishing I had 4x4, which is why I spent the extra $$ for 4x4 this time.
  #13 (permalink)
Old 10-02-2007, 07:13 PM
Can anyone tell me if you command 1st gear in 4lo do you get it? Per the manual it says that you do not get 1st gear in 4lo with the trans in drive. Can anyone verify that you can lock in 4lo 1st gear. RPMs should run a hair over 2000 rpms at 5 mph. Hate to be picky but this would be a great help.
  #14 (permalink)
Old 10-03-2007, 05:19 AM
Baumbach Baumbach is offline
Baumbach is starting off with a positive reputation.
Quote:
This is correct, in 4 low it does not start out in 1st, you need to manually shift into 1st t get it. I realized this while on a boat ramp, unless you manually put it in 1st gear while in 4 low it would drift backwards
  #15 (permalink)
Old 10-03-2007, 10:58 AM
Thanks for the help. That is what I was wondering. If it's second gear, that's not the greatest but since you can command 1st that is a stout ratio. Boat ramps can always be fun, I've used one where it took a F-350 Dually and F-350 SRW to pull a 28 ft boat out at low tide.
Tags
2010, 4lo, advancetrac, button, car, disconnect, expedition, f150, ford, icon, rsc, rtt, shut, sliding, traction
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
