tons of pm's on my 10k
  #136
Old 04-23-2010, 05:19 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
First, if you're running a chip or tuner, you don't need the BB mod (FPR Shim). The chip or tuner should make the adjustment.
Second, 45 - 60 PSI at idle, at the schrader valve, with a chip, is on the low side of the normal range. Normal pressure range is roughly 40 - 80 PSI at idle. You don't want to go over 80 PSI with a stock fuel system. If the needle is bouncing between 45 and 60, then your pressure is probably closer to 52 - 53 PSI at idle. Add the lowest reading to the highest reading and divide by two to give you an average estimate for your starting point.
I'm thinking the chip isn't working properly.
I suggest removing the chip and rechecking your fuel pressure. If it's still low, add a BB as stated and recheck your fuel pressure. There is also a screen you'll want to clean. I unbolted my FPR to clean it. You can drain the fuel filter bowl and do it that way, too.
Use a cotton swab, with the cotton removed. I prefer the paper-material shaft, but you can try the plastic one if you want. Gently use the shaft to wipe away the crud on the screen.
Adding a BB and cleaning this screen should give you a slightly smoother idle, better throttle response, and an overall happier engine. I gained 0.5 mpg after doing this.
Search for 'FPR Shim' and you should find plenty of info with pictures. You should also find info on how to clean the screen.
Let us know how it goes.
  #137
Old 04-23-2010, 06:13 PM
fordpride's Avatar
fordpride
fordpride is offline
(Quote)First, if you're running a chip or tuner, you don't need the BB mod (FPR Shim). The chip or tuner should make the adjustment.
The chip can not change your fuel pressure as the pump is manual pump not controlled by PCM
pj check your fuel pressure with a stick style gauge an if your fuel press. is over 60psi then you don't need to shim it and the way that your gauge is jumping that normal.
  #138
Old 06-17-2011, 02:05 PM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Originally Posted by c00nhunterjoe
my inbox is swamped with the same question, how did i do my 10k, 14.7, 15.6k mod, so hopefully this will clear it up, here is a simple step by step with pics to do the 10k.
step 1: buy the materials shown, a- resistors, b- box of spade terminals, c- electrical tape
step 2 get the resistor out of the pack as shown here
step 3- fold each end over to make for a good crimp point as shown here
step 4- put 1 male spade on one end of resistor and one female spade on other end of resistor as shown here
step 6, wrap resistor in tape to prevent any shorts or excessive vibration.
no picture needed for that one
step 7, cut signal wire for icp. while looking at connector it would be the mouth
of the smily face as shown here
step8- strip each end of your wire and crimp one male spade to one end, crimp one female spade to the other end. this allows for swapping different size resistors or putting it back to stock with no other modification needed, no picture needed for this either
step 9- drop the resistor in place as shown here
the mod is done in less then 5 minutes, if you want to make a 14.7 or 15.6 mod then you simply crimp a 4.7k or 5.6k inline with the 10k and the time goes up to a total of 6 minutes, try it out and enjoy the boost in performace for a grand total of 5 dollars, each pack of resistors is .99, pack of terminals is 3.00 for the good ones
Hey Joe, where did the pictures go?
  #139
Old 06-17-2011, 10:13 PM
Talyn's Avatar
Talyn
Talyn is offline
You need some? I have my version of it up on my website if your looking for some pictures.
  #140
Old 06-17-2011, 10:45 PM
Talyn's Avatar
Talyn
Talyn is offline
Midnight Mods: ICP Resistor Mod – Version 1
here is my version of it. I planned on doing more versions, but shortly after got a chip and never worked on it more.
  #141
Old 06-18-2011, 05:45 AM
DIYMechanic
Yeah I was looking for the pictures the other day, but since this is part of the Tech / Mods sticky it would be nice if the pics were up there for anyone else to see as well. I guess they are right here now!
Thank you Mr. Stone, you're so smooth!!
  #142
Old 06-18-2011, 07:16 AM
Talyn's Avatar
Talyn
Talyn is offline
I got the fuel bowl mod one coming up as well. Just need a few hours to sit down and put it together.
scatgo
Offroad & 4x4
134
02-11-2011 10:47 PM
bigpowerstroke
13
12-24-2010 12:28 PM
brickie
08-01-2010 10:44 PM
4inchlovin
19
04-16-2010 11:46 PM
c00nhunterjoe
77
12-09-2008 11:20 PM
Quick Reply: tons of pm's on my 10k
