intercooler swap?
Here's some more links if your interested
http://www.gts-motorsports.com/icinstall.html
http://www.gts-motorsports.com/inter...lpictures.html
https://www.ford-trucks.com/user_gal...&albumid=25248
BTW.. The Hot pipe needs more work done to it for it to fit. A simple 3" extension on it should do the trick. This is displayed in the above links. The Cold side works pretty well too, just needs to be cut and turned a little.
Good Luck
Good Luck
on
this pic is a 6.0 cac with a V10 transmission cooler....
http://good-times.webshots.com/photo...34541150LmTTlF
I have since upgraded to a 6.0 tranny cooler, and its about 2x as big
as the V10 cooler...(sorry no pics yet) but it works ALOT better...
i can tell on a 6.0 IC i had to the grill to fit back over the IC and on my truck with the 7.3 IC if you made your brackit for it i geuss you could get something behind it.but why would you want to put it behind it.if you have to replace it or fix a leak you would have to tear the front of the truck apart for a 5 min fix.
