Transmission Pan Gasket - Ford Truck Enthusiasts Forums
Old 09-18-2007, 07:51 PM
mdpitt's Avatar
mdpitt mdpitt is offline
mdpitt is starting off with a positive reputation.
Hi folks wanted to know from those who have dropped their transmission pan to change filter or fluid is the pan Gasket reusable? Regard
2003 5.4l 4x4 150
Old 09-18-2007, 08:17 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
On my E4OD it was, in fact it was recommended I reuse it rather than stick a new cork one in there.
Old 09-18-2007, 09:02 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the 4R70 is molded rubber and reusable. the one in the filter kit is cork- throw it away.
Old 09-18-2007, 09:08 PM
fast68 fast68 is offline
fast68 is starting off with a positive reputation.
reusable yes
when we dropped ours the first time(last spring)it had a aftermarket cork one on it that a PO had installed
we got the factory rubber one from the dealer
but only after using the new cork one we got originally,
however the transmission was leaking and we erroneously thought it was the pan leaking so we dropped it again andinstalled the factory rubber one
still had a trans leak after that even,
so now the other day i dropped the pan again and used a 5 dollar squeeze tube MoPar ATF RTV black silicone to seal the pan on so now we have a perfectly good new factory rubber gasket laying around that we will never need hahaa
i think it was only 20 bucks though or little more though,
dropping the pan is easy on these, although the rear lip of the pan gets kinda hung up
what i do is drop and raise the pan up and down a few times while puling the pan forward and it comes out
otherwise its cakewalk on these
clean and easy
the 4r70w or whatever trans, the smaller/lighter one
with the 4.9 engines
the bolts are 10mm head
need a short socket and universal joint for the two rear ones because the crossmember is in the way too far to get them with just the straight extension and socket
if for some reason you cant get the factory rubber one i could send you this one for mail cost or whatever
if the 5.4 even used the same tranny as the 4.9 though.,
flat rate is low
but im sure your local ford dealer will have quite a few
i would think
good luck
Old 09-18-2007, 10:09 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
I have dropped my pan three times now and still have the original rubber gasket from the factory on it with no leaks.
New Pan Gasket Leaking aclaybor 1987 - 1996 F150 & Larger F-Series Trucks 14 04-06-2015 12:43 AM
Trans leak emmagator 6.0L Power Stroke Diesel 0 11-10-2014 10:37 PM
Oil Pan Gasket Jim_work 1987 - 1996 F150 & Larger F-Series Trucks 0 05-30-2014 02:52 PM
change oil pan gasket Bigal700 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-09-2014 12:49 PM
Need a new pan gasket? Tyler.172 1994.5 - 1997 7.3L Power Stroke Diesel 10 04-23-2014 05:57 PM
Tags
1980, 1997, 1999, 2003, 54, e4od, f150, f250, find, ford, gasket, pan, pictures, reusable, reuseable, tranny, transmission, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
