setting valve lash - Ford Truck Enthusiasts Forums
setting valve lash
Old 09-18-2007, 03:06 PM
hellbilly1932 hellbilly1932 is offline
hellbilly1932 is starting off with a positive reputation.
setting valve lash
I am trying to reassenble my 292 and having some trouble with the valve lash. This is my first time doing a valve adjustment on an engine with solid lifters and push rods (my motorcycle has a similar rocker arm set up but it is an OHC design) I am following the instructions from my 1959 ford truck shop manual, a reprint from C & G Early Ford parts which reads:
Set #1 at TDC on comp stroke then adjust
#1-Ex #1-In
#4-Ex #2-In
#5-Ex #7-In
Rotate crank 1/2 turn to bring #4 to TDC then adjust
#6-Ex #4-In
#8-Ex #5-In
Rotate crank 3/4 turn to bring #3 to TDC then adjust
#2-Ex #3-In
#3-Ex #6-In
#7-Ex #8-In
This is for the cold setting at .019
When I do it this way and get it done some of the push rods are so lose at points throughout the turn of the crank that they just fall down and are not in contact with the rocker arms. Actually its alll of them at some point.
Does this make since?
all my parts are still with the same cylinder from when it was torn down, nothing was mixed up, all push rods stright and same length. It just dont seem right to have the push rod get so loose that the little cupped end falls away from the rocker arm.
Old 09-18-2007, 04:39 PM
RCA78SS RCA78SS is offline
RCA78SS is starting off with a positive reputation.
Check to make certain #1 is on the compression stroke. #1 is passenger side front, by the way. Remove all spark plugs and have a helper hold their thumb on the #1 spark plug hole while you rotate the crankshaft clockwise. They should be able to feel pressure as the #1 piston begins its compression stroke. Stop at TDC and follow the instructions you already have.
Old 09-18-2007, 06:55 PM
Ok nevermind, I got to stop smoking crack for breakfast! Thanks guys.
Old 09-22-2007, 03:18 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
If you don't have the "lock-nut" type rockers you can adjust with the engine running.
It's a little messy but it works.
Old 10-26-2008, 12:58 PM
mr1955truckman mr1955truckman is offline
mr1955truckman is starting off with a positive reputation.
Problems with my 1955 Ford Truck
hey guys! i have tried to make a valve lash adjustment on my 1955 ford truck. The problem is that my rocker is still noisy for some reason. The truck manual says .16 on intake and .18 exhaust which is right but i have adjusted them at .19 both like shop manual says. Which one is right I can't figure it out. email me at my grandaughters email address Caleighhhx46@aim.com. Please help! Thank you.
Old 10-26-2008, 02:44 PM
flipklos flipklos is offline
flipklos is gaining momentum as a positive member of FTE.
.19 is cold lash for inital break in
.16/.18 are hot lashes, and are done after a good warm up period.
If you just rebuilt the engine set it at .19 till after run in is complete.
I set mine at .16 by rotating the crank 1/2 turn 4 times and looking for play.
Old 10-26-2008, 07:14 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
It is very possible the rockers havent been replaced or reserviced for many thousands of miles. If that is the case, they WILL have wear pockets at their end from valve contact. You can adjust the valves perfectly by feeler gauge, and they still will be extra loose by the depth of the pockets. So while you are in there take one of the adjusters all the way out and run a finger on the contact surface, or use a dentist's mirror and take a look at the end of one, to get an idea of their condition. They all will be basically the same with regards to wear.
Any auto machine shop can resurface them for not much, especially if you dissassemble the rockers yourself.
Old 02-10-2009, 10:54 PM
1959_f100's Avatar
1959_f100 1959_f100 is offline
1959_f100 is starting off with a positive reputation.
how do you do that
I think I hurt my 460, help please. 68murc Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 2 08-11-2015 06:15 PM
Valves will not stay adjusted!...Help? uncs77 1973 - 1979 F-100 & Larger F-Series Trucks 10 01-13-2015 08:54 PM
Pedestal rocker arm installation question mark1986F150 Ford Inline Six, 200, 250, 4.9L / 300 11 12-14-2012 08:37 AM
Valve lash adjustment 81 for 300 6 gordo2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 07-06-2011 12:47 PM
1972 351 Windsor Push Rod Length 60 F100 4X4 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 7 10-28-2010 11:04 AM
Tags
1959, 239, 292, 312, adjust, adjustment, adjustments, block, ci, clearance, ford, lash, settings, static, v8, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
