You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I will have lots of questions and lots to share, all related to my two 1966 Econoline pickups.
First, I would like help decoding my VIN plate. Most of the info is quite clear and the Ford Shop manual catches most of it. However, there is the DSO that I need help with. I believe this is a 1966 Spring Special. It is red with chrome side moldings, chrome dash, oil gauge and temp gauge, alum trim parking lights, and chrome glove box door.
VIN: E10AH734354
WB: 090
COLOR: J
MODEL: E100
BODY: E87
TRANS: C
AXLE: 07
MAX GVW: 3800
NET HP: 129
RPM: 4000
DSO: 71
The Chrome dash Plate and glove box door was someones doing afetr market. Someone had them electroplated. (Chromed)
It seems you have most of the vin tags decoded except that DSO. I'm not sure what that means. I think it is a Dealership Special Order, wild guess. Maybe numberdummy who has lots of tidbits on these things may pop in and answer this.
If you are still having problems with the rest of the vin plate, let us know I can see about deciphering it for you as best I can.
I am VERY new to this website, and now the new parent of a 1963 Ford Econoline Pickup Truck. I would also like to have the VIN decoded, so that I may see what I have. My E-100 also has a plate showing its history as belonging to the United States Air Force, and I have noticed it has a Ford 9" rearend. Other than that, I need help please. Below is all of the markings on my VIN plate:
E01SH392764
090
E103
87A
A
02
3800
79
4000
830034
Any help would be greatly appreciated. Thanks again.
Hi Law, you will want to pick up a Ford Shop manual for '63. You can find them on e-bay for $20 ish. Most of your codes will be explained in the front....my '66 manual doesn't have the letters I need (no "S" engine for example--I am guessing that goes to a 144 cu in engine. Also, I show axle code 02 as the small 7 1/4" rear end 4 to 1 ratio). You may have something unique there, that multiple digit DSO code is related to the order that was received from the US Air Force, probably. It could have some unique combinations.
If you do not get someone coming on shortly, I found another forum over on Yahoo called 'econosrus' and there are some really dedicated econo chaps there.
Warranty number should read E10 instead of E01 -transposed?
Series E10 pickup
S - engine 6 cyl. 144 C. I.
H - place of Manufacture - Lorain, Ohio
392764 - unit number of manufacture in March 1963
E103 designates regular pickup
Body 87A - pickup
A - trans - manuel
02 - Axel - 4.00:1
3800- max. G.V.W.
79 - cert. net. H. P. @
4000- RPM
830034 DSO - Domestic Special Order - 83 - Government ordered & number of order 00034
This should help.
