302 what year
The C8OE means the block was designed for 1968 model year. This basic casting was used for a few years, so your block could be 1968 to early 70s. The 8 H 5 1 5 5 7 0 number is a little mysterious, but if it were 8 H 5 it could be a date code and thus would indicate the block was cast in 1968, August (H), 8th day.
I believe he posted the VIN number, nothing more. That's where it was stamped when it was done. The date code is next to the casting numbers. It's a number/letter/number(s) combo. These are the year/month/day of the month. Month runs alphabetically starting with "A" for January thru "M" for December, they skipped the letter "I"
Good clarification from Baddad. I didn't know that Ford put the VIN number on its blocks. Anyhow, hopefully from his instruction you can get the real date code. It still will probably be dated 1968-early 70s. So it will be 28oz-in balance, two piece rear main seal.
Does it still have the crankshaft in it? This will help date the motor (assuming it's all original) because 1969 and earlier will have the crank pulley held on with 3 bolts while 1970 up uses 4 bolts.
65fordguy
01-21-2008 01:59 PM
Sunny_in_hollister
12-07-2001 10:54 AM
