You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
OK so i am wondering if it is possible to make or brew your own biodiesel (science fair). I need to be able to brew my own biodiesel at home because i am not going to spend 4 grand to convert my truck over to run on biodiesel. I am just going to test the effects of biodiesel vs regualr diesel. EGT's, MPG. If it is possible to make biodiesel using home materials plus the cost of buying vegatable oil or any other kind of oil then please tell me how or give me a website that has specific directions. Also how safe is it to make biodiesel. I mean i have read things that say that without removing chemicals from the oil that act as delubricants you can burn injectors up. SO if any of you make biodiesel at your home and then dump it in the tank (if its possible) could you please make a direction write up for me. Then if it would be ok to site you in my reference page.
THanks Adam
__________________
"I lie down and sleep; I wake again, because the Lord sustains me."84' Ford F-250 4x4 single cab IDI - No Turbo MODS: Soup Bowl/ ram air, 3" exhaust most of the way, aftermarket tach worth 25+ HP !
Are you talking about converting to straight vegetable oil (SVO)? Your statement is very confusing. Biodiesel requires no "conversion" for the vehicle.
If you mean to you personally, physically, making the fuel, you have to know what you are doing, and it's very similar to high school chemistry class.
If you mean to your vehicle, that all depends on the quality of your fuel.
This makes no sense. When you're making biodiesel, you do a chemical reaction that separates out the glycerin from the vegetable oil molecule. Biodiesel is used as a lubricity additive, it has such a high lubricity.
Well Turboman24 as far as brewing your own at home your on your own, but go pick up January 2006 Diesel Power has a article on Biodiesel and April 2007 has a article Diesel Power also. Hope it helps.
We have a couple of farmers here that buildt their own soybean processing unit to make biodiesel. It cooks the beans runs them through a press, then reheats them and press them again to get the most oil out of them. What is left they use as a cow feed additive.
__________________
2000 F250 4 x 4 88,000 miles as of 05/11/2009, conventional cab, longbed,Reese rail system gooseneck hitch
synthetic motor oil
six speed manual transmission.
AIS intake, 4" turbo back Magnaflow S/S exhaust
inlet & outlet pyrometers & boost gauge
You do not have to convert your truck to run on BioDiesel.
Quote:
You should also evaluate the production of air pollutants
Cleaning homemade BD is an absolute must.
There are several methods ranging from water washes to "dry washing" with Magnesol. Dry washing produces the best result with fewest problems.
The best source here is FABMANDELUX
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
