removing door panel on a 2003 f150 - Ford Truck Enthusiasts Forums
Old 09-17-2007, 06:41 AM
tutiii tutiii is offline
tutiii is starting off with a positive reputation.
i need to remove the door panel on my 2003 f150.
i have a problem with my speaker.
is there a trick to removing this panel?
thanks
Old 09-17-2007, 07:00 AM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
The panels lift up after you remove the bolt holding the door handle on.
Old 09-17-2007, 09:41 AM
ggarrahan ggarrahan is offline
ggarrahan is starting off with a positive reputation.
1) Remove the upper trim panel on the rear of the door adjacent to the window. This trim panel has 2 clips on it, and it simply snaps off.
2) Remove the trim plate around the door handle. It also just snaps off.
3) Remove the window/mirror control switch panel from the door. This panel also snaps off, but it has a plastic tab on the rear, so begin by carefully lifting the front (narrow) part of the switch panel, and once disengaged, slide the panel towards the front of the door to clear the tab.
4) Now, remove the cables from the switch panel, and don't worry, they can only be re-installed one way.
5) OK, you should see two phillips head screws. One is under the upper trim panel you removed in step#1, the other is under the door handle trim plate removed in step #2. Remove these two screws.
6) Now, release the panel by moving it slightly outward to clear the door handle, then pull upward. DO NOT try to pry the panel off, you will break the plastic mounting tabs molded into the rear of the panel. Also, pay attention to the door lock at the top rear of the door panel as you remove. The door lock remains in place as the panel is lifted to be removed.
7) Installation is the reverse of removal.
Note: If you have manual windows (is there such a thing anymore?), then the window regulator handle will need to be removed, usually on a Ford there is a screw in the center under the plastic housing which snaps off and is moved to the side for clearance.
You should have no problem, actually it's the easiest panel I've ever removed!
2001 F150 Extended Cab Door Panel Removal zombey 1997 - 2003 F150 3 11-05-2010 06:48 PM
Door Panel removal dmcenery 2004 - 2008 F150 1 10-25-2008 09:52 AM
Removing door panels VandeBogart 1997 - 2003 F150 4 07-22-2007 11:13 PM
98door panel removal vinman46 1997 - 2003 F150 8 06-24-2004 06:58 PM
removing door panels 2003 f-150 American Muscle 1997 - 2003 F150 5 12-05-2002 08:39 PM
Tags
2003, door, f150, ford, heritage, light, manual, panel, panels, pickup, pull, rear, removal, remove, removing, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
