What "all original" means (with a GP Question)
*In a positive way it means that your vehicle has not been molested by the previous owner and/or many repair shops. Such as broken bolts, wiring issues, crossthreaded bolts, stripped threads, and others.
*In a negative way that means that you just bought a vehicle with all original parts that are nearing the end of the lifespan. Such as glowplugs, clutches and so on.
Now to the point, I have an "all original" truck, and all the glowplugs are out. I ohmed them and got infinity on all. Then I tried the test light way and it didnt light.
Is it more possible for all eight glowplugs to go out (for how long I dont know) or for the glowplugs pins on the UVC harness to go out?
What is the torque value for the injector holddowns? rocker arms?
I got 14ftlbs for the GPs and 8ftlbs for the VC bolts, correct?
jumper cables man. if you got em out grab below the threads with the ground and put the positive on the top where the wire plugs onto. dont burn yourself. if there still good you will know real quick they get glowing red in about 1 second.
what all did you rip apart on your truck? the gp's come out without removing the rockers. sorry books are at home.
Rocker Arm Post Attaching Bolts 27 ftlbs
Fuel Injector Hold-Down Clamp Mounting Bolt 20 in lbs
Fuel Injector Hold-Down Clamp Shoulder Bolt 20 in lbs
Valve Cover Bolt 97 in lbs
but all four VC harness's, only on the glowplug terminals? wouldnt it be more realistic that all eight glow plugs went out sometime in the last 13yrs/170k miles? It was a southern truck so the previous owner possible couldnt tell the difference in starting cause it wasnt cold enough. I'm gonna remove the passenger side VC and ohm out the GPs there.
How easy does the passenger side VC comeoff?
just to make shure i understand. this is what pins in the UVC harness connector are. and to test the Glow plugs if you connet an ohm meter between a ground (neg battery post) and the glow plug pins you should get "0.00" on a digital and a full sweep to the right on an analog meter if they are good. the same as if you touch the two leads of the meter together.
Cuda_Jim: removing the passenger VC was easy, didnt even remove the insulation or anything else. The only hard part was the 2 rear bolts. I disconnected the glow plug wire from the GP and did a ohm and test light test straight on the GP, but nothing happened, so I got 8 OEM motorcraft GPs coming from eBay cause no parts strore around here sells the motorcraft/beru brand, just bosch, autolite, champion, ac delco.
can you say lawsuit.... threaten with that, i still get starters replaced on the race car, long tube headers eat mopar starters, even with heat shields. if they advertise lifetime and there is no fine print stating otherwise on the origonal receipt then they MUST honor it. been there done that.
as for all 8 gp's i've seen that many times before, if a relay sticks on it will burn them out real quick, if all 8 are bad throw a relay on it too, it only has to stick once to burn them out again
