Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 09-16-2007, 05:36 AM
oldfart oldfart is offline
Garage is empty, add now
oldfart is gaining momentum as a positive member of FTE.
Power window problem...need some advice.
Folks I posted this problem in the Home page but thought to post it here as well. My problem is the drivers side power window has been acting balky of late and then yesterday it went all the way down and won't go back up! Arrrghhh! No blown fuses and the motor does, on occassion, make some whiney noises..but no lift. I assume the door panel has to come off. How do I do it without damaging anything. (like the little plastic buttons that hold it in place) Any special tools? Any tips or advice would be welcome. I have about 5 free hours next Tue. to effect some repair or at least block the window in the upright position until I have more time to repair it correctly. Meanwhile I'm praying for no rain!! Thanks to all in advance. YMHS.Audie..the oldfart!!
  #2 (permalink)
Old 09-16-2007, 09:15 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Hey ..Sound like the gears may be stripped. (Should be in help isle of parts store. ) Remove all screws around and you can get tool to pop .Remove screw at window switch . I just start at bottom and pull work my way up and down till comes loose. Same for back . Open vent window pick up on pannel come forward to clear door Handle . Take time and buy new pugs at local parts house. You may take off fine but you don't want rattle later. Have a good day. With any luck you might just need to clean things up .
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
  #3 (permalink)
Old 09-16-2007, 10:51 AM
ranger1999 Bob's Avatar
ranger1999 Bob ranger1999 Bob is offline
2011 Ford Escape
My Garage
ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.
Robert Olson
i dont know what year your truck is but if its like my old one the door panels are plastic and they wont break the little plastic holdrs are cheap and replaceable and can be found in the motormite/help section of the auto parts store.. I usually pry them up one at a time gently . the first riveet i get is the one in the lower corner then i stuck my hands under there and pull each oen gently ( 89 F 250) this is after i take out the phillips screws that hold the other things in and i unbolt the hex screw on the window crank ( you wont have that with power windows) Its not hard at all to do
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
