Rear Driveshaft Cap Bolt Size
I have a 2000 F-350 Crew cab SD 4X4 with a 7.3 and I developed a vibration in the rear of the truck. I went to take the drive shaft out and and check the u joint. I can't find a wrench or socket to fit the bolts on the rear axle yoke. 5/16" is to big 9/32" is to small 8mm is to big and 7mm is to small. What the heck kind of stupid size did Ford use? Or do you have to go to Ford for a special tool. Any help would be appreciated.
Amish65F100
20
08-03-2017 09:40 PM
CountryBumkin
25
06-21-2017 10:25 AM
carlsson
1999 to 2016 Super Duty
12-07-2011 05:49 PM
