Rear Driveshaft Cap Bolt Size - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-15-2007, 08:51 PM
shortstuf shortstuf is offline
shortstuf is starting off with a positive reputation.
I have a 2000 F-350 Crew cab SD 4X4 with a 7.3 and I developed a vibration in the rear of the truck. I went to take the drive shaft out and and check the u joint. I can't find a wrench or socket to fit the bolts on the rear axle yoke. 5/16" is to big 9/32" is to small 8mm is to big and 7mm is to small. What the heck kind of stupid size did Ford use? Or do you have to go to Ford for a special tool. Any help would be appreciated.
Old 09-15-2007, 09:53 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Double post
ReAX's Avatar
Sounds like you need a 19/64s I would guess. I haven't done my superduty, but the last Ford I pulled a driveshaft on had 13mm bolts.
Old 03-26-2010, 10:16 PM
JJJMN JJJMN is offline
JJJMN is starting off with a positive reputation.
The bolts at the Pinion are 8mm. You'll need a 6 point box end wrench to get them off. I tried a 12point 8mm box end and just rounded off the points on the wrench. Had to go to sears and got the only 6 point box end they had.
Old 03-27-2010, 06:47 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Nevermind, didn't read carefully.
Doesn't sound right, how about a pic?
Old 03-27-2010, 07:42 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
I would hope the OP got it fixed by now considering this thread is over 2 1/2 years old...
brake bleeder screw size? cjben 1987 - 1996 F150 & Larger F-Series Trucks 6 08-26-2015 12:24 PM
Coil "COP" bolt seized and head twisted off inside intake arctic_driver 1999 to 2016 Super Duty 5 03-22-2015 04:38 PM
2006 Eddie Bauer Expedition caliper bolt size...it's NOT 9MM cs641 1997-2006 Expedition & Navigator 0 07-04-2014 09:19 AM
5.4 block coolant drain plugs allen tool size? carlsson 1999 to 2016 Super Duty 5 12-07-2011 05:49 PM
What size bumper bolts??? jaycrow Ranger & B-Series 1 08-31-2003 08:57 PM
Tags
1999, 2008, 98, bolt, bolts, drive, driveshaft, expedition, f150, f350, ford, joints, rear, shaft, size, star, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
