Using Biodiesel in Winter - Ford Truck Enthusiasts Forums
Old 09-15-2007, 06:57 PM
barnbridge's Avatar
barnbridge barnbridge is offline
barnbridge is gaining momentum as a positive member of FTE.
A local fuel supplier has recently started carrying B-20. My 2004 PSD runs well with it and I'm happy with the lubricating properties of biodiesel. As winter approaches I'm wondering if I should use anti-gel fuel additive or if biodiesel is blended in winter like #2 Diesel is. Anyone know the pourpoint of B-20? I suppose I could always put a jar of it in the freezer and see what happens.
Old 09-15-2007, 09:44 PM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
There are severe diminishing returns to the lubricating properties of Bio after B5, I wouldnt run any more than that during the winter due to the possibility of gelling.
Old 09-15-2007, 10:11 PM
adambomb's Avatar
adambomb adambomb is offline
adambomb has a good reputation on FTE.adambomb has a good reputation on FTE.
taken right from the biodiesel.org website.
Quote:
Be aware of biodiesel's cold weather properties and take precautions
as with #2 petrodiesel use in cold weather.
A 20 percent blend of biodiesel with petrodiesel usually raises the cold
weather properties 2 to 10 F (pour point, cloud point, cold filter plugging
point). In most cases, this has not been an issue. Twenty percent biodiesel
blends have been used in the upper Wisconsin area and in Iowa during -25
F weather without issues. Solutions to biodiesel winter operability problems
are the same solutions used with conventional #2 petrodiesel (use a pour
point depressant, blend with #1diesel, use engine block or fuel filter heaters
on the engine, store the vehicles near or in a building, etc.).
http://biodiesel.org/pdf_files/fuelf...ts/bdusage.PDF
I personally have not had any cold weather issues using bio yet. Last winter when I went to go snowboarding i was running soy b100 and it got down to the low 30's and my truck started up perfectly in the morning. The cloud points also depend greatly on the feedstock the bio is made from.
Old 09-16-2007, 07:44 AM
ron's power stroke's Avatar
ron's power stroke ron's power stroke is offline
ron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud ofron's power stroke has much to be proud of
where i live we see 30 to 50 below 0 a lot in january and febuary and we have a dealer that sells B 50 in the summer and B5 all winter ..he adds some anti-gel stuff to it but i still run white bottle DK in it and carry a bottle of diesel 911..i have had no problems and still have a new bottle of 911..
Old 09-16-2007, 03:05 PM
adambomb's Avatar
what does the diesel 911 do? is it like an instant anti-gel?
Old 09-16-2007, 04:20 PM
Quote:
yes it is...i never had to use it yet..not sure how good it really is..i have heard good things about it..
Old 09-17-2007, 05:31 PM
Wheatina's Avatar
Wheatina Wheatina is offline
Wheatina is starting off with a positive reputation.
I haven't had experiences with anti-gel additives, but came across this one specifically made for BD.
http://www.powerservice.com/aeba/default.asp?view=app
Anyone use this before?? Where do you get it??
Fuel additives with biodiesel? mah77 6.0L Power Stroke Diesel 5 08-07-2011 12:06 PM
Question about biodiesel H2oSprayer 6.0L Power Stroke Diesel 29 10-30-2010 01:17 PM
Hey, Austin! BioDiesel and Additives? lakerats Texas Chapter 2 12-27-2006 02:59 AM
How Much Cheaper is Biodiesel? mcn420 General Diesel Discussion 10 10-23-2005 03:49 PM
Biodiesel power onioncasserole Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 03-08-2005 10:55 AM
Tags
biodiesel, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
