Kam code
As far as I know KAM stands for Keep Alive Memory...it is where the OBDII system stores info about the problems it finds in the trucks systems. I have no idea why you would find that as an error though. We usually get DTC codes reported, this is the first time I have ever heard of a KAM error.
Originally Posted by suzuki_vinson
Yes i just put a juice with attitude on it yesterday. It seems to be doing better. I cleared the code and let it sit for a while. Im a little nervous tho about the programmer. It seems to give it alot more power. But sounds like its knocking or something when it idles.
Originally Posted by Tenn01PSD350
Well your fun with Edge has just begun. Hope you get better support than some I have heard here. To answer your question though, the KAM error is likely tied to the tuner and not a cause of the knock, (the KAM error), the knock is likely from increased oil pressure to the injectors from the tune.
Uhmm, well, I better shut up because the links escape me at the moment, but I have seen posts about customer support when Edge stuff goes on the fritz and it wasn't pretty. Since I have not archived any of that I will shut up except to say I have seen them.
We agree where the KAM error may come from and that is probably about it. I am sure the Edge tunes are far better than stock. So is a 10K mod too though.
EDIT: BTW, my #8 LL injector is louder with my DP as it was with the TS. He has a LL too.
Originally Posted by SLAYER1
when i had the edge on my truck when i got on it hard i would see the check engine light flash momentarily, one of the codes i always got was the kam
It will depend on which Kam Error code you have
P0603/P0605 is normal to read off after installing a chip or programmer or you disconnected the batteries or there was some kind of power loss to the PCM.
P0606 is questionable. It does mean internal PCM failure, but doesn't mean it is completely toasted. Recoverable, maybe. ???
Which code are you getting?
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
