How much torque on 360 head and intake bolts? and pattern... - Ford Truck Enthusiasts Forums
Old 08-20-2002, 11:49 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Old 08-21-2002, 09:42 AM
74dually 74dually is offline
74dually is starting off with a positive reputation.
Hey guys,
I am putting reworked heads on my 360. I need to know how much to
torque my head bolts and intake bolts. Also,
Do I need to torque my rocker arm nuts? Do I need to adjust them while engine running or just torque them down.
Thanks,
Peyton
P.S. you start on one thing and it opens up a whole can of
worms....:-)
Old 08-21-2002, 01:56 PM
William William is offline
William is gaining momentum as a positive member of FTE.
Cylinder heads in sequence first to 70FP, then 80fFP and final to 90FP. Start in the center of the head with the center bolts, alternating front to rear. Or from the center of the head towards the end. The intake is also torqued in sequence from the center to the four corners, then to the intermediate bolts. Final torque is 35FP. If you are not comfortable with this text I suggest you get a repair manual or buy the book Building Big Block ford Engines by Steve Christ.
William in Atlanta
Old 08-21-2002, 08:33 PM
William,
Thanks, I torqued them and my intake. I have purchased a Repair manual CD Rom thru FTE, but have not received it yet.
Thanks again.
Peyton
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 03:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 12:40 PM
ooops Aerostar 5 01-14-2015 03:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 06:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 10:21 PM
Tags
1968, 1973, 360, 72, bolt, bolts, ford, head, intake, order, pattern, ram, tighting, torque, toruqe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
