07' F150 Screw 5.4L 5.5' XLT Owners Manual & 4x4 - Ford Truck Enthusiasts Forums
Old 09-12-2007, 01:58 PM
damone damone is offline
damone is starting off with a positive reputation.
Manual says only to drive 30-miles in 4x4.
Is there any truth to this or just dont go 30+ miles in 4lo?
Old 09-12-2007, 03:43 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Never heard anything like it...
My owner's manual says this:
Using the electronic shift 4WD system (if equipped)
2H (2WD High) - Power to the rear wheels only; used for street and
highway driving. Provides optimal smoothness and fuel economy at high
speeds.
4H (4WD High) - Used for extra traction such as in snow or icy roads
or in off-road situations. Not intended for use on dry pavement.
2007 F-150 (f12)
Owners Guide (post-2002-fmt)
USA (fus)
Driving
259
4L (4WD Low) - Uses extra gearing to provide maximum power to all
four wheels at reduced speeds. Intended only for off-road applications
such as deep sand, steep grades or pulling heavy objects. 4L (4WD Low)
will not engage while the vehicle is moving above 3 mph (5 km/h); this is
normal and should be no reason for concern. Refer to Shifting to/from
4L (4WD Low) for proper operation.
Shifting between 2H (2WD High) and 4H (4WD High)
Move the 4WD control between 2H and 4H at any forward speed up to
55 mph (88 km/h).
Note: Do not perform this operation if the rear wheels are slipping.
Note: Some noise may be heard as the system shifts or engages; this is
normal.
Shifting to/from 4L (4WD Low)
1. Bring the vehicle to a complete stop
2. Place the transmission in N (Neutral).
3. Move the 4WD control to the desired position.
If shifting into 4L (4WD Low), wait for the 4X4 LOW light in the
instrument cluster to turn on indicating the shift is complete.
If shifting out of 4L (4WD Low), wait for the 4X4 LOW light in the
instrument cluster to turn off indicating the shift is complete.
normal.
It can be engaged in speeds up to 55 MPH, but DO NOT EVER do this on dry roads!!!
Old 09-25-2007, 08:36 AM
skipy skipy is offline
skipy is starting off with a positive reputation.
I you have your truck at 55mph in 4Low...you're a fool!
Old 09-27-2007, 02:23 PM
Quote:
Actually, it's the only way to go wheelin
Old 09-27-2007, 02:46 PM
last5oh_302's Avatar
last5oh_302 last5oh_302 is offline
last5oh_302 is starting off with a positive reputation.
Quote:
Old 09-27-2007, 02:56 PM
MBBFord's Avatar
MBBFord MBBFord is offline
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
I would get on the black top and start driving in 4Hi.
IF you do it, it more than likely won't hurt much of anything(just more wear), but you're on hard ground, can't get stuck, no need for 4x4(or the slight possiblity of binding the t case).
I wouldn't drive on the road in 4Lo at all, just off road.
Old 12-03-2012, 08:59 PM
luvmy98ranger5L luvmy98ranger5L is offline
luvmy98ranger5L is starting off with a positive reputation.
if u can move at 55 m/h(88km/h) as fare as my experiemnce tells me u don't need 4wd low and are wasteing engine pwer and
92 transmission rustyranger92 Ranger & B-Series 1 10-12-2016 08:36 AM
Front Differential Noise? Sbroom 1987 - 1996 F150 & Larger F-Series Trucks 1 12-23-2015 11:13 AM
2003 F 150 4x4 not engaging mt.dave 1997 - 2003 F150 1 11-20-2012 11:32 AM
5w20 vs. 5w30 vs. 0w30 DTS419 1997 - 2003 F150 51 04-20-2008 01:06 AM
5.4 with 100k, which oil is best? rangedog Modular V8 (4.6L, 5.4L) 5 11-01-2003 04:21 PM
Tags
07f150, 2007, f150, manual, owners, screw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
