odometer problems 97 f150 - Ford Truck Enthusiasts Forums
Old 09-12-2007, 02:25 PM
Brian Lawrence Brian Lawrence is offline
Brian Lawrence is starting off with a positive reputation.
first, how do I disassemble my dashboard to get at the odometer?
Old 09-13-2007, 09:35 PM
02crew's Avatar
02crew 02crew is offline
02crew is starting off with a positive reputation.
is your light going out? use the search option. my buds expedition has that problem and there is a post that tells how to fix it but i dont think it tells how to take the dash appart?start pulling off panels around the steering wheel it should be easy enough to figure out.
Old 09-14-2007, 04:27 AM
Peetza Peetza is offline
Peetza is starting off with a positive reputation.
odometer easy fix
http://www.f150online.com/forums/sho...d.php?t=126765
Takes about an hour or so if you're careful and don't want to scratch anything. Fixed mine better than new. Great instructions. Read the post further to get the headlight switch to come right off easily.
Old 09-14-2007, 11:48 AM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
IIRC the `97 F-150 was not available with the digital odometer, old style reels only.
odometer blackout 04badford 6.0L Power Stroke Diesel 8 11-24-2013 12:41 PM
Odometer not working Kaizer88 Ranger & B-Series 3 07-13-2012 01:58 PM
Odometer seams funny rpfarm25 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-19-2012 12:36 AM
6 digit odometer va150 1987 - 1996 F150 & Larger F-Series Trucks 4 10-15-2008 06:30 PM
2002 Explorer XLS Compass and Trip Odometer knuckles Explorer, Sport Trac, Mountaineer & Aviator 5 01-25-2004 09:48 PM
Tags
150, 1997, 2000, 2002, 97, blue, econoline, f150, ford, issue, issues, odometer, problem, problems, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
