Turn signals stopped working and Im tired of hand signals...
I was pullin' a buddy out who was stuck in some nasty stuff last weekend and all went fine and dandy until I got back on the pavement and I realized my turn signals arent working. My hazards work. So I am guessing something got knocked loose in the column. Im not sure where to start looking/testing. I have a grant steering wheel on there and I have no idea how to get it off. The truck is a 75 F250. HELP PLEASE!!!
PS. My buddy is has a Dodge on 44s... I walked right through the same spot.
God bless 4 lo with granny 1st!
did the fuse blow when you put it in and tried it? maybe there is moisture in the sockets have you had all the light bulbs out? this is a simple electrical system on these trucks so it should pretty easy and straight forward to figure out. check all bulb sockets. clean and dry them.. replace fuses and flashers and it should work, unless there is a broken wire or a short somwhere..
ray
ray
ray
ray
YAY!
I switched the modules... when I put the flasher module on the hazards i could hear it "pop" a really fast, but it didnt show anything on my dash. And when I put the hazard module on my flasher, I got nothing. No sound, nothing on the dash and nothing for actual signals.
And I tested the fuse connections and they are just fine.
What else you guys got?
