Engine swap snafu - Ford Truck Enthusiasts Forums
Engine swap snafu
Old 09-10-2007, 01:50 PM
plankofwood64 plankofwood64 is offline
plankofwood64 is starting off with a positive reputation.
Engine swap snafu
I'm new to this site. This is my first post.
I bought a 1998 f-150 with a blown 4.2. I bought a remanufactured 4.2, put it in, etc...
this is my problem - when I connect the battery the interior components; radio, idiot lights, fan, horn, all work but the engine won't crank. I'm trying to prime the oil pump but can't. I blow a 25 amp fuse (the one located under the hood) whenever I connect the positive cable to the battery.
I took my multimeter, set it to "tone", and touched the negative to the negative post of the battery (with the cable connected) and the positive to the positive cable, (NOT on the battery) and I got a tone. So somewhere I have a positive grounding out to something.
Have anyone experienced this? Am I overlooking something obvious with my connections?
Any help would be greatly appreciated.
Thank you
Eric
Old 09-10-2007, 09:07 PM
dragogt's Avatar
dragogt dragogt is offline
dragogt has a great reputation on FTE.dragogt has a great reputation on FTE.dragogt has a great reputation on FTE.dragogt has a great reputation on FTE.
why did the engine blow? where did you get the truck, friend, auction, E-bay?
how's the cable going to the starter?
Old 09-11-2007, 05:03 AM
It used to be a Haz Mat fleet vehicle out of North Carolina. I bought it from a friend whose son-in-law works for Haz mat.
The exact reason why the motor blew is beyond me, but it did throw a rod through the oil pan. (a hole the size of your index finger)
I bought a remanufactered engine, (long block) from Green Leaf Motors out of Monroe Georgia.
It's wired to the starter like so: ground from the battery to the ground bolt on the starter, positive hooked up to it's post on the selenoid. When I connect the cables to the battery it blows a 25amp fuse that's located on the right side of the engine bay in the fuse box located there.
I've got a Haynes repair manual, Chiltons FYI online manual, and the starter is hooked up per their instructions.
I'm at a lost here. Any ideas? Perhaps there's a chasis ground I'm missing? I know theres a ground wire connected to the frame by the right front tire that goes to the starter. Any others? There's also a ground wire connected to the back of the engine bays wall, (just above left of the intake), grounded to the wall) that I have no idea where it goes. Any more?
Old 09-11-2007, 07:31 AM
dragogt's Avatar
I'm not familiar with those trucks, but you might try posting in the 1997 -2003 forum,
got some pretty smart guys there, should be able to get you fixed up.
I just thew out the starter as a w-t-h.
good luck
Old 09-11-2007, 01:54 PM
for reasons I can't explain........ It cranked.
Now what's the procedure for priming the oil pump?
Any reply is greatly appreciated
Old 09-12-2007, 09:39 AM
dragogt's Avatar
disable coil, and fuel --- (unplug the coil, trip the fuel pump safety switch) and spin Until you get pressure
then, don't forget to reconnect you coil and reset the fuel pump. and you should be good to go
have fun
Old 09-12-2007, 12:43 PM
Thank you!
It worked like a charm. Now all I have to do is connect the vacuum lines to their correct location and I'm golden.
Again, some help on this woulkd be greatly appreciated. I have the schematic from Chilton's DIY online manual, but it's all greek to me.
Anyone have photos or some other means to help a novice along?
Thank you.
Eric
Old 09-12-2007, 02:21 PM
dragogt's Avatar
congrats bubba,
sorry, but i don't have any info on those truck's.
have you asked the guys in the 1997- 2004 forum, they should have every thing you need to hook up your vacuum lines
OT mystery oldbird1965 1994.5 - 1997 7.3L Power Stroke Diesel 16 10-21-2014 11:42 PM
Anything special to know about changing the positive battery cable? Golden Helmet Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 11-01-2013 10:42 AM
Do I need THREE Negative cables on a '79 F150 battery cable clamp? ScullyisaFox 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-29-2011 10:39 PM
Extending a battery terminal with a copper "bus" bar? busflyer 1999 to 2016 Super Duty 3 05-02-2011 02:35 PM
General question: Replacing (-) negative battery cable on a 97 Ranger? kryp2o Ranger & B-Series 3 04-11-2006 02:45 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
engine, isuzu, rodeo, snafu, swaps, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
