6-speed fluid change advice needed
For those that remember I broke the back section of my zf-6 speed. Finally got around to fixing it, 230 dollars in parts. I was going to change the oil when I had it out on the ground until I was quoted 21 dollars a quart for fords synthetic atf. I was in a hurry to get it back together so I plugged the vent and cooler lines so not to spill any. I've used royal purple products before with no problems, but not sure if I should use the synchromax manual transmission fluid, or the max atf, synthetic. Or if anyone could reccomend another product to use.
A while back I had mentioned to cookie that I was running the RP syncromax in my ZF6. He told me that royal purple specifies that if your tranny is a ford manual tranny that requires ATF, run the RP auto tranny fluid. I dropped the synchromax and replace with Mobil 1 syn. That was over a $100 dollar mistake.
While you are dropping the tranny fluid, stop by your local Napa and pick up a can of tranny flush. This way you can flush you lines and cooler in order to start from fresh. I did this before and I was suprised at what came out of the lines. Mostly black crap. A can was like 10.00 dollars.
Go pick up a can of tranny cooler flush. Its a rattle can that can screw on to your cooler lines. Blow it out with the can, then some compressed air and reconnect, check fluid level and rock on...
Hi guys....need some quick help!
I'm changing my tranmission fuild as we speak. My manual said it was 3.4 quarts capacity....after making a mess and overflowing my catch pan it's obviously not. Does anyone have the correct capacity for the ATF?....I can't find it anywhere.
Next problem is I didn't buy enough ATF!
Thanks!
Thanks!
Thanks!
Thanks!
After digging around deep I found one site that claims the capacity is 13 Pints/6.5 Quarts if you have the cooler. There are two lines coming out of the transmission on the right side...I would assume these lead to the cooler?
Is there a step by step for newbies like myself on changing the fluid correctly and smartly?
Feel like a *******! I'm still use to the small stuff on the SAABs and Volvos!
I managed to get 90% of what came out back into the transmission. I'm sure it's slightly low...should be ok for light driving tomorrow. Weather looks like crap tomorrow....my garage needs to be taller!
Little update....I'm going to put the old ATF back for today as the sun is falling fast. Don't want to rush this and waste the new SYN ATF.
Hoping to beat the rain today. Anyone have any words of wisdom or ideas?
