6-speed fluid change advice needed - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-10-2007, 12:20 PM
77hiboyboy's Avatar
77hiboyboy 77hiboyboy is offline
77hiboyboy is starting off with a positive reputation.
For those that remember I broke the back section of my zf-6 speed. Finally got around to fixing it, 230 dollars in parts. I was going to change the oil when I had it out on the ground until I was quoted 21 dollars a quart for fords synthetic atf. I was in a hurry to get it back together so I plugged the vent and cooler lines so not to spill any. I've used royal purple products before with no problems, but not sure if I should use the synchromax manual transmission fluid, or the max atf, synthetic. Or if anyone could reccomend another product to use.
Old 09-10-2007, 12:50 PM
Fat Diesel's Avatar
Fat Diesel Fat Diesel is offline
Fat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud ofFat Diesel has much to be proud of
I've used Mobil 1 Syn ATF several times and have tortured it to 230* without issue.
Old 09-10-2007, 03:19 PM
pullinair pullinair is offline
pullinair is gaining momentum as a positive member of FTE.
Lightbulb
A while back I had mentioned to cookie that I was running the RP syncromax in my ZF6. He told me that royal purple specifies that if your tranny is a ford manual tranny that requires ATF, run the RP auto tranny fluid. I dropped the synchromax and replace with Mobil 1 syn. That was over a $100 dollar mistake.
While you are dropping the tranny fluid, stop by your local Napa and pick up a can of tranny flush. This way you can flush you lines and cooler in order to start from fresh. I did this before and I was suprised at what came out of the lines. Mostly black crap. A can was like 10.00 dollars.
Old 09-10-2007, 03:45 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I second the tranny cooler flush. When I replaced my tranny last year, I did the same and was shocked at how much crud came out, not to mention how much better it flowed afterward!
Old 10-26-2009, 06:37 PM
Old and Busted's Avatar
Old and Busted Old and Busted is offline
Old and Busted is starting off with a positive reputation.
I know this is an old thread. Having trouble finding a link to flushing the fuild in the ZF transmission. Anyone have it or have any other thoughs on fluid?
Thanks!
Old 10-26-2009, 07:48 PM
Rockrunner86's Avatar
Rockrunner86 Rockrunner86 is offline
Rockrunner86 is starting off with a positive reputation.
Quote:
Thanks!
Go pick up a can of tranny cooler flush. Its a rattle can that can screw on to your cooler lines. Blow it out with the can, then some compressed air and reconnect, check fluid level and rock on...
Old 11-29-2009, 02:49 PM
Hi guys....need some quick help!
I'm changing my tranmission fuild as we speak. My manual said it was 3.4 quarts capacity....after making a mess and overflowing my catch pan it's obviously not. Does anyone have the correct capacity for the ATF?....I can't find it anywhere.
Next problem is I didn't buy enough ATF!
Thanks!
Old 11-29-2009, 03:06 PM
Thanks!
Little update....I'm going to put the old ATF back for today as the sun is falling fast. Don't want to rush this and waste the new SYN ATF.
After digging around deep I found one site that claims the capacity is 13 Pints/6.5 Quarts if you have the cooler. There are two lines coming out of the transmission on the right side...I would assume these lead to the cooler?
Is there a step by step for newbies like myself on changing the fluid correctly and smartly?
Feel like a *******! I'm still use to the small stuff on the SAABs and Volvos!
Old 11-29-2009, 04:15 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
I actually never new the manuals had a cooler...
I'm guessing there's some kind of mechanical pump to push it through the cooler. Where is the cooler located? Up front?
Old 11-29-2009, 04:34 PM
Light faded fast, but I traced the lines forward and they appear to lead to a cooler under the main radiator. There must be some kind of pump inside the transmission since the lines coming out the side of the transmission appear to be above the fill plug.
I managed to get 90% of what came out back into the transmission. I'm sure it's slightly low...should be ok for light driving tomorrow. Weather looks like crap tomorrow....my garage needs to be taller!
Old 11-29-2009, 04:39 PM
fordzilla01's Avatar
fordzilla01 fordzilla01 is offline
fordzilla01 is starting off with a positive reputation.
I was surprised that the Manual actually has lines that connect to a section of the Radiator. I will drop the rest of the fluid out of my tranny when I go to put my new motor in.
Curious, if it takes 3.4L of fluid, does that include the cooler fluid?
Old 11-29-2009, 08:13 PM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
The Ford version does indeed have a pump and cooler. GM used the same tranny and they didn't have a cooler.
Interesting about the Royal Purple. I was considering going to the syncromax, now I guess not.
Barney
Old 11-29-2009, 08:17 PM
Izzy351's Avatar
Yeah, I tried syn gear oil in my '84 Mustang's T5, and it blew apart. Bad advice from a "knowledgeable" mechanic. Worked out though -- I ended up with a C6 auto & 351W to put in it...
Stick with ATF.
Old 11-30-2009, 08:11 AM
Bump.
Hoping to beat the rain today. Anyone have any words of wisdom or ideas?
Old 11-30-2009, 11:06 PM
Bump.
I never kept track of how much, but it needs to be filled up to level with the bottom of the fill port.
Synthetic ATF in the Aerostar? focusyn Aerostar 24 07-16-2014 09:40 PM
What fluid, for 5speed grad 1997 - 2003 F150 1 02-17-2014 08:10 PM
Synthetic ATF for TorqShift 5R110 UaVaj 1999 to 2016 Super Duty 41 09-07-2013 05:10 PM
Synthetic ATFs redman84 1994.5 - 1997 7.3L Power Stroke Diesel 16 04-26-2013 12:05 AM
Synthetic transmission fluid. Break in for Syntetic oil? ebduda Oil & Lubrication 12 11-01-2002 01:19 PM
Tags
6speed, 73, 73l, changing, fluid, ford, forum, purple, royal, spd, speed, synchromax, transmission, trucks, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
