6-speed fluid change advice needed - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-30-2009, 11:47 PM
Old and Busted's Avatar
Old and Busted Old and Busted is offline
Old and Busted is starting off with a positive reputation.
Quote:
Originally Posted by Kwikkordead View Post
I never kept track of how much, but it needs to be filled up to level with the bottom of the fill port.
Thanks...I've since hunted around and found it's about 6.5 quarts. Most of my concern was having the wrong info on the capacity....I only had a rough guess on what I was able to recover that didn't spill.
Do you know if the cooler drains back into the transmission when the motor is off? Plan on changing the fluid tomorrow and wanted to know if I'm good with just filling to the bottom of the fill port or if I need to recheck once the cooler has 'refilled' itself
Old 12-01-2009, 09:31 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
It doesn't drain back.
Besides, having too much oil in the tranny will only result in airation.
Just fill it to the bottom of the port and drive. It will be fine.
Old 12-01-2009, 06:01 PM
Thanks. Good to know....guess I was just over thinking the whole thing.
Old 12-02-2009, 06:50 PM
Finished with flushing the transmission fluid today. I picked up the transmission flush can from NAPA, but was unable to get the cooler lines to back off....bummer. It will have to wait.
I've been thinking of adding a transmission fluid filter to the cooler lines. Dieselsite.com has a nice kit. Dan or anyone played around with this yet for your 6 speed? Is it overkill?
Old 03-09-2012, 11:09 PM
dmanshane's Avatar
dmanshane dmanshane is offline
dmanshane is starting off with a positive reputation.
i am running john deere 80w/140 synthetic gear oil in mine she likes it shifts nice when warm little harder when cold but quiter no more of that notorious grinding noise
Old 03-10-2012, 12:54 AM
4inchlovin's Avatar
4inchlovin 4inchlovin is offline
4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of4inchlovin has much to be proud of
Quik wheres Stewart with one of his "revive old threads" pics....
Old 03-10-2012, 01:03 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Here you are, Nolan.
Stewart
Old 03-11-2012, 03:39 AM
4inchlovin's Avatar
ewy.... ah... thanks?
Old 03-11-2012, 07:38 AM
dieselbronc's Avatar
dieselbronc dieselbronc is offline
dieselbronc is starting off with a positive reputation.
I'd like to run the 85/140 in mine for the noise they make ,and the miles it has, but was told not to, is it ok to ?
Old 03-11-2012, 11:19 AM
dmanshane's Avatar
My theory is is fine it's gears what can it hurt semi transmissions run gear oil and the back boxes are sncronized yes the Down side is it shifts harder while cold sometimes in the 1-4 gears you have to float shift cuz the clutch don't help lol but let her warm uP for ten minutes or so she shifts like a dream
Old 03-11-2012, 08:19 PM
Im talkin about the fact that it came with ATF switching to gear oil,besides the flow thru the cooler.
Synthetic ATF in the Aerostar? focusyn Aerostar 24 07-16-2014 09:40 PM
What fluid, for 5speed grad 1997 - 2003 F150 1 02-17-2014 08:10 PM
Synthetic ATF for TorqShift 5R110 UaVaj 1999 to 2016 Super Duty 41 09-07-2013 05:10 PM
Synthetic ATFs redman84 1994.5 - 1997 7.3L Power Stroke Diesel 16 04-26-2013 12:05 AM
Synthetic transmission fluid. Break in for Syntetic oil? ebduda Oil & Lubrication 12 11-01-2002 01:19 PM
Tags
6speed, 73, 73l, changing, fluid, ford, forum, purple, royal, spd, speed, synchromax, transmission, trucks, zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
