my 1987 F350 Shakes Violently
Old 05-09-2010, 03:31 PM
reflection's Avatar
reflection
reflection is offline
My 1987 F350 Dually Shakes Violently Left & Right at over 35-40 mph.
Never experienced anythig like it I mean the whole cab & truck shakes back anfd forth??
Any help would be appreciated.
Old 05-09-2010, 03:47 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
It feels like the front tires are falling off, right?
It sounds as though your caster is off. It is quite common on F350s. you need a degree shim to correct it
Old 05-09-2010, 03:48 PM
ymeski56's Avatar
ymeski56
ymeski56 is offline
Der Postmeister
Or worn Tie Rod bushing
Old 05-09-2010, 03:58 PM
reflection's Avatar
reflection
yes it feels like the front tires are falling off. Where is the caster adjustment located on the truck and do they sell different degree shims??
I am very mechanically inclined and have always worked on my own vehicles but this is my first larger truck.
Thanks for your help
Old 05-09-2010, 04:00 PM
reflection's Avatar
reflection
Old 05-09-2010, 06:45 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Check your tires...............Tread getting ready to separate and causing a bulge will cause BAD vibration before dramatically failing at a very bad time.
Old 05-09-2010, 06:50 PM
Diesel_Brad
They make slugs to adjust the caster and camber for the ball joint D60 but you should have a king pin. They make degree shims you put between the springs and the axle for the king pin D60
02f250lariat
1999 to 2016 Super Duty
04-30-2014 10:48 AM
tnardo
12-13-2009 10:18 AM
wild7_SDF-250
07-22-2009 10:32 AM
jaykelly75
06-06-2007 11:15 AM
Gladiator
08-11-2003 08:21 AM
Quick Reply: my 1987 F350 Shakes Violently
