Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 09-09-2007, 06:27 PM
rolloff rolloff is offline
Garage is empty, add now
rolloff is starting off with a positive reputation.
peanut oil in 6.0
Has anyone mixed peanut oil with diesel fuel in a 6.0 Ihave about 5 gallons from a turkey fryer . if so how much per tank .
  #2 (permalink)
Old 09-09-2007, 06:41 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.bigredtruckmi has a good reputation on FTE.
You will first have to filter it to 5 microns so it will pass thru the fuel filter without problems.
__________________
red 04 F250 build date 04/04 6.0 PSD ,auto,cc, xlt ,sb, moon roof, 4X4, off road pkg, sports pkg., tow pkg,camper pkg,FX4, electric shift on fly
93 f350 7.3 , 5 speed manual, ext cab, long box 240K+ miles
1967 C700 farm truck
30 ft travel trailer
Vietnam Vet/ OS1 USN/USNR retired 26 years
B5 soydiesel user
Sirius radio
  #3 (permalink)
Old 09-10-2007, 10:54 AM
vwbuge vwbuge is offline
vwbuge is starting off with a positive reputation.
I can't tell you about the 6.0 or any power stroke for that matter. However, I have been running a 50/50 mix of WVO and diesel for the past 3-4k miles. I make sure it doesn't have any water in it and I filter it through a pillowcase into a 55 gallon drum.
  #4 (permalink)
Old 09-13-2007, 10:18 AM
davE350 davE350 is offline
davE350 is starting off with a positive reputation.
[quote=rolloff]Has anyone mixed peanut oil with diesel fuel in a 6.0 Ihave about 5 gallons from a turkey fryer . if so how much per tank .[/QUOTE
It's not as simple as dumping it in. If you did a search on WVO, Waste Vegetable Oil, you get all the info you need.
What you are doing is called Blending. Some guys go as high as 85% WVO.
With a little at 25% in your diesel tank you will start to smell like French Fries.
I just read an independent study lab Listed Soy oil as the best Lubricant of all. I'm sure peanut oil would also be close to that.
When Rudolf Diesel intruduced his engine design, that was what he ran it on, peanut oil!
Have fun,
davE350
__________________
86 E350
Kubota small farm tractor
(need a bigger one to run a Back Hoe)
Tags
60, ford, oil, peanut
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
