95 F350
Old 09-10-2007, 05:58 AM
zzzzzz's Avatar
zzzzzz
zzzzzz is offline
95 F350
OK, Here's the problem, Getting on entrance ramp to interstate towing 20 ft boat and the truck seems like its stuck in 3rd gear no power then engine tachs up hi like its in neutral. Pull over, No forward but it will go in reverse. Is it new transmission time? Its a 460 srw 4x4 overdrive. What is the trans model? Thanks for any help you guys can give me. Tom
Old 09-10-2007, 06:37 AM
JLDickmon's Avatar
JLDickmon
JLDickmon is offline
could be...
when was the last time you changed the filter and flushed it?
Old 09-10-2007, 06:41 AM
zzzzzz's Avatar
zzzzzz
zzzzzz is offline
a while back,30k or so
Old 09-10-2007, 06:59 PM
kcb37's Avatar
kcb37
kcb37 is offline
Sound like you may have a burned up clutch or two.
Old 09-10-2007, 07:10 PM
94' 460 F350's Avatar
94' 460 F350
94' 460 F350 is offline
if you have overdrive its a E4OD i would get the tranny flushed and put in a bottle of lucas trannsmission fix, worked wonders on my truck , but i do agree sounds like one of you clutches is bad, try and put it in 1st and 2nd then 3rd will ir go into any of those gears? what does the trany fluid smell like? burnt? remember you arnt supose to tow in overdrive there is too much heat build up and you dont have enough torque in overdrive
Old 09-11-2007, 05:04 AM
zzzzzz's Avatar
zzzzzz
zzzzzz is offline
Thanks guys Its toast, I'm putting in the ford reman this week. 3 year 36 warrantee. I figure its worth it. The truck has 120k on it NO rust anywhere and the paint is still shiny. I get compliments everywhere I go with it.
E30tdf
02-06-2008 05:19 PM
tom1979
02-15-2007 06:02 PM
FX4x4x4
2004 - 2008 F150
70
08-18-2004 01:23 PM
FX4x4x4
2004 - 2008 F150
08-02-2004 11:47 AM
tjahl
1999 to 2016 Super Duty
07-13-1999 09:39 PM
Quick Reply: 95 F350
