I'm guessing you located your PCM? Try ebay. Search using PCM and ECM, will be listed under either. There is a code on your PCM. Call your dealer and find out which numbers/letters have to match up when purchasing a new/used one.
It turned out to be two wires at the EDIS plug that were chewed by mice. The computer is good. Funny, I just seen one on ebay for $35 with my exact numbers. Thanks to all that replied.
