91 Explorer PCM Location? - Ford Truck Enthusiasts Forums
Old 09-09-2007, 10:58 AM
swj123 swj123 is offline
swj123 is starting off with a positive reputation.
Can someone please tell we where the PCM is located in the car? Thanks
Old 09-09-2007, 11:03 AM
Backin72 Backin72 is offline
Backin72 is starting off with a positive reputation.
Remove the kick panel on the front passenger side, should be right there.
Old 09-09-2007, 08:59 PM
Does anybody know where I could get a replacement reasonable? Thanks
Old 09-10-2007, 12:12 PM
I'm guessing you located your PCM? Try ebay. Search using PCM and ECM, will be listed under either. There is a code on your PCM. Call your dealer and find out which numbers/letters have to match up when purchasing a new/used one.
Old 09-10-2007, 12:15 PM
Thanks, I did locate the PCM. I will look on ebay for one. Thanks, Mike
Old 09-11-2007, 04:03 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
Are you sure the PCM is bad?
Old 09-11-2007, 04:28 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
another post said it was not.
rarely the computer goes bad.
Old 09-11-2007, 04:36 PM
It turned out to be two wires at the EDIS plug that were chewed by mice. The computer is good. Funny, I just seen one on ebay for $35 with my exact numbers. Thanks to all that replied.
89 PCM location spaytons 1987 - 1996 F150 & Larger F-Series Trucks 3 05-06-2015 05:19 PM
Engine & Trans Computers (PCM & TCM) location? 1999_Super_Doody 6.7L Power Stroke Diesel 2 03-24-2015 02:06 PM
PCM Code Location 1997 F250 varmintboy54 1994.5 - 1997 7.3L Power Stroke Diesel 11 05-14-2009 08:53 PM
Pcm Code Location Firefighter 1406 1999 - 2003 7.3L Power Stroke Diesel 22 07-30-2008 11:04 AM
1995 F-150 PCM location and wiring diagram mtntop Electrical Systems/Wiring 3 06-25-2003 01:39 AM
Tags
1991, 1993, 1995, 91, 91explorerpcm, 94, 95, diagram, ecm, explorer, f150, ford, location, pcm, placement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
