Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 09-09-2007, 12:32 AM
77' ranger f250 is starting off with a positive reputation.
Need help designing exhaust system my Y-Block
I've been reading for hours about exhaust systems but still need advise.
My truck is a 1964 f-250 with a stock 292 (two barrel, for now). I have some Reds Headers shorties on order. From there back I don't know if it's best to do a single or dual system. Some say a small stock v-8 doesn't need dual exaust. Also, What size pipes, I'm thinking 2" or 2 1/4". For sound I want a mellow , low reasonance, but throaty sound upon accelaration. For mufflers I'm interested flowmaster hushpower II's, dynomax turbos, or even a mellowtone glasspack. Any suggestions would be helpful.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-09-2007, 12:53 AM
46yblock is starting off with a positive reputation.
Yeah you should have duals. 2 inch is fine in my book, or even 1 7/8. I put on Cherry Bombs. Inexpensive and readily available.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #3 (permalink)
Old 09-09-2007, 07:50 PM
pcmenten is starting off with a positive reputation.
I suggest that you use a crossover and that the mufflers are mis-matched to prevent droning. Don't go over 2" in diameter, like Mike says, 1 7/8" might be better.
__________________
Best regards,
Paul Menten
  #4 (permalink)
Old 09-09-2007, 09:59 PM
Good advise, When you say miss-matching, do you mean two different models of mufflers, or same mufflers but different size. And by crossover, you mean an H-pipe somewhere behind the headers?
  #5 (permalink)
Old 09-09-2007, 10:10 PM
Yes, H-pipe, and yes, different size mufflers.
I learned about the different muffler thing after I bought my 86 Mustang GT. This car came from the factory with different sized mufflers to prevent droning.
__________________
Best regards,
Paul Menten
  #6 (permalink)
Old 09-09-2007, 11:44 PM
And by different size mufflers, you mean longer in lenth? or larger inside diameter?
Let's use an example and say I go with 1 7/8 pipe. Then what would you recommend for size mufflers.
  #7 (permalink)
Old 09-10-2007, 09:37 PM
Different sized cases, like a 22" on one side and a 24" on the other size. As long as you have an H-pipe, I don't think the slight flow difference matters - the H-pipe will equalize it.
__________________
Best regards,
Paul Menten
  #8 (permalink)
Old 09-10-2007, 11:46 PM
The different size mufflers, 22 in. vs. 24 in., makes some empirical sense to me. I have no way of figuring it out mathematically. However, if it also requires an H pipe, I wouldnt mess with it.
My two Cherry bombs without H hum, and it has become kind of nice. Drowns out the electric fuel pump, but isnt good for stereos or conversation.
__________________
1990 Ranger 4WD
  #9 (permalink)
Old 09-11-2007, 11:11 AM
HT32BSX115's Avatar
HT32BSX115 is starting off with a positive reputation.
What's this "Droning" you're talking about?
I had dual exhaust on my 57 Ford Fairlane when I was a kid and I don't remember anything strange about the exhaust note.....I also did not have a cross-over either.
I'm not planning to use glass packs or any other sort of loud muffler on mine. I have a regular 6in dia x 30" (I think) muffler and I was just going to get another identical muffler for it.
What are you guys talking about?
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #10 (permalink)
Old 09-11-2007, 12:49 PM
Someday Rick maybe you will have a chance to ride in mine. But if so, talk loud ha ha.
__________________
1990 Ranger 4WD
  #11 (permalink)
Old 09-11-2007, 07:04 PM
Quote:
It's the sound dual exhaust sometimes makes a certain RPM, when they hit a certain harmonic and it's really loud inside the cab.
My brother had dual 40 flowmasters and at 1800 rpm it was horrible. So I'm trying to avoid this. Needless to say I'll start by NOT getting flowmasters 40's. -But I am interested in their Hushpower II's. But they're $129 each! Not sure if they're worth it.
  #12 (permalink)
Old 09-11-2007, 09:05 PM
kooper909's Avatar
kooper909 is starting off with a positive reputation.
I just built a 292 for my '60, and I was planning on the 1 7/8" with Cherry Bombs also. I do have a 4-barrel Edelbrock though.
__________________
1960 Ford F-100. '57 292, 3 speed. Mild traditional custom daily driver with red scallops and wide whites.
  #13 (permalink)
Old 09-11-2007, 11:14 PM
HT32BSX115's Avatar
I'll take that as an invitation!
Quote:
__________________
  #14 (permalink)
Old 09-11-2007, 11:45 PM
Definitely. If you are ever in this area make sure to stop by. Rick did you get the manifolds back from their ceramic coating?
__________________
1990 Ranger 4WD
  #15 (permalink)
Old 09-12-2007, 02:08 PM
HT32BSX115's Avatar
No. I haven't heard from them yet. They told me to expect a call sometime this week.
On the way up there I'm going to drop by "High Strength Bolt" in Kent, Wa and get the studs. I also want to use brass exhaust manifold nuts on the bolts to hold it all together.
When I get them I'll take some high res pictures and post them in the gallery.
I'm also thinking I'll stop by Specialty Metals and get myself a piece of 3/8 aluminum so I can make myself a valley cover. I like the idea of using a router to make a "lip" to fit in the valley.
Then I'll probably use a drill and dowel to put swirls or something on it.
I can make a tube and weld it on for an oil fill and another for a breather/ oil seperator.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
