Thermactor ports
on
i tapped my heads and installed a SS plug into them. the port is actually a stepped hole, that is there is a larger outer hole and smaller inner hole. the inner hole is sized perfectly for i think it was a 1/4" npt tap and plug. just put a lot of grease on the tap so no shavings get inside the head and into the engien.
they do make plugs to fit these holes as they are a weird size, but the tap method was easy to do.
rgds
Mike
rgds
Mike
BigBlocker0248
01-20-2016 06:41 PM
Ed Bamba
01-27-2015 09:21 PM
FEmtnmax
08-27-2003 08:38 PM
