Cool Tips and tricks - Page 22 - Ford Truck Enthusiasts Forums
  #316
Old 07-27-2013, 08:39 AM
Tobys50's Avatar
Tobys50 Tobys50 is offline
Tobys50 is starting off with a positive reputation.
Lightbulb Defrost Vents on 48 - 52's
I was finally piping defrost hoses up to the vents in my dash when I discovered I only had the "cup" for one side. Unable to locate another one readily, I decided to improvise, destroying a perfectly good floor-hose end attachment from my shop vac. I had to use a hacksaw and rotate the neck on it so it pointed the other direction, but now the defrost hose doesn't interfere with the wiper linkage! I started by taping it to the underside of the dash to pre-drill some holes, ran some sheet metal screws in it, drew'er up and attached the defrost hose! I may end up doing this to the other vent just to get the hose away from the wiper linkage! I know it sounds trashy but it works like a champ!
*side note: since the defrost hose is such an odd diameter to find in a material flexible enough to route the way you want it, and without having to order it, I found "carburetor/air cleaner" aluminum hose @ Autozone to work perfectly. $6 for each and you're done.
-Toby
  #317
Old 09-15-2013, 03:12 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
This isn't the right place to be posting questions, it's for tips and tricks. Start a new topic and you'll get a lot more responses.
  #318
Old 09-15-2013, 04:17 PM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
Quote:
Posts moved to 48/56 truck forum.
  #319
Old 12-09-2013, 09:18 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Hillbilly Parts Washer
50 gallon drum, 40 gallons of water, a small box of "TSP" and a gallon of PineSol. Dirt and poorly-adhered paint don't stand a chance. I heated it with two of my home made blacksmith's propane burners.
This is a test of my ability to post pictures as well.
  #320
Old 12-15-2013, 11:33 AM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
I don't know if this has been posted before but I used an old ac condenser between my compressor pump and tank as an intercooler to try to lessen the among of condensation in the tank. It works fine keeping the air cooled that is going into the tank.
I had some hoses made with compression fittings in one end and -6 & -8 fittings on the other ends to accommodate attaching the condenser.
I attached the condenser to the belt guard in front of the fan built into the compressor flywheel to optimize air flow.
  #321
Old 12-15-2013, 01:43 PM
jniolon's Avatar
jniolon jniolon is online now
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
grizz,,
do you have any type drain on the condenser ?? what do you do about water collection... cool idea... will start search for condenser tomorrow
  #322
Old 12-15-2013, 03:53 PM
BACAGrizz's Avatar
No drain on the condenser. Don't think it needs it because the pressure in the condenser bleeds off when the compressor shuts off. Condensation happens when the tank gets hot and cools. With this setup only cold air goes into tank so much less condensate.
I still have water separating units on the air lines by have been noticing much less water in the tank from the drain on the bottom of it.
  #323
Old 12-16-2013, 11:53 AM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is offline
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
OK, while it looks neat, I don't see how that lessens the amount of moisture interring the compressor tank. Where does the moisture go? is it in the bottom of the AC condenser? If so, it would appear that sooner or later, there will be so much water in the unit that it will begin to fill up the air tank anyway. Maybe a bung welded unto the bottom like a normal radiator with a drain valve would provide a place to purge the condensed water? Jag
  #324
Old 12-16-2013, 12:27 PM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to allpetemcl is a name known to all
Why not just drain the tank and the condensate trap occasionally? The part of an A/C system that removes water from that sealed system is the receiver/dryer, but even if you added that I don't think that they are designed to remove water from an unsealed system.
Are you having that much of a problem with water? Maybe I'm missing something?
  #325
Old 12-16-2013, 01:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Condensers are designed for pretty low flows compared to an air compressor's output, it may restrict flow. There are also different types of circuits in them, for this application I believe a serpentine would be best, as water can't hide out in it. You should have a drain pot right after it.
  #326
Old 12-16-2013, 10:27 PM
AXracer's Avatar
every time you make the flow turn a corner you create a large restriction in the flow. Try one of those curly retractable water hoses sometime, it cuts the flow rate to less than 1/2. The curly air hoses or roll back hose reels do the same, don't use them where the flow rate is critical, spray painting, high volume air tools, etc.
Also use as short a flexible hose as you can, stretch it out as straight as possible, don't leave it coiled up while using.
  #327
Old 12-16-2013, 11:07 PM
BACAGrizz's Avatar
I do drain the tank manually. The way it was explained to me was the cooler you keep the tank and incoming air the less water it will produce. Condensation comes when the tank gets hot and cools. If the tank stays cool you will get less water from the air. I am looking into putting a desiccant dryer to further inhibit condensation. Just having cold air going into the tank has cut down a lot on the water forming in the bottom of the tank.
The water never gathers in the condensor because the air doesn't stay in it for long, it only passes through. The pressure bleeds off when the compressor turns off so, the trapped air in the condensor exhausts and doesn't have the chance to expel its water. Only the top 2 or 3 runs ever get warm.
I got the idea from a local compressor sales and service store. They tried to sell me an intercooler for $250 and I got this one from a friend for free. It does the same job as the fancy schmancy intercooler.
Ross, that is exactly the condensor I have, a serpentine aluminum unit. Very efficient for my application.
  #328
Old 07-05-2014, 10:41 AM
Paul52 Paul52 is offline
Paul52 is starting off with a positive reputation.
Hi Truxx56. I love your idea about using clear plastic to make templates for metal pieces. I have used cardboard for a while which worked well for the perimeter but had a hard time placing the holes correctly. This string for sharing tips is a great idea. Cheers Paul52
  #329
Old 07-05-2014, 11:17 AM
Thank you for posting all of those great tips Jniolon. These are of great value to us novices when working on our truck projects. This is a very helpful thread. Cheers Paul52
  #330
Old 07-16-2014, 10:28 AM
jhweigel's Avatar
jhweigel jhweigel is offline
jhweigel is gaining momentum as a positive member of FTE.
My favorite high tech diagnostic tool
I made a 3 foot long jumper wire with alligator clips on each end. I used 14 gauge silicone hookup wire because it is very flexible. I have been trouble shooting the temp sensors on my flathead V8 (8BA) motor. Just jumpered across each wire between the two sensors, and each wire going to the gauge to check continuity, then check the temp gauge to see if any change occurs. Then I grounded the temp gauge to make sure it went all the way to "cold" then took off the jumper and it returned to "Hot" (with the ignition switch on) to verify that the gauge is working.
Sometimes simpler is better.
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 09:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 06:03 PM
Fuel,temp,and oil gauge Wiring for 12 volt neg. ground Jeepcamp 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-05-2014 07:56 PM
12v to both neg and pos side of coil army89 1967 - 1972 F-100 & Larger F-Series Trucks 12 05-16-2011 09:23 PM
Gauge Electrical Short! potemkin 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2008 11:00 AM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
