Cool Tips and tricks - Page 21 - Ford Truck Enthusiasts Forums
  #301
Old 05-02-2013, 10:22 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Neat set up, the only thing I'd add would be a convenient switch so you don't have to keep reaching past the grinder to turn it off. I don't like reaching over, past anything that is spinning and could grap a piece of clothing or cut skin.
  #302
Old 05-02-2013, 01:31 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
BTDT already! LOL :)
Was just looking at it yesterday and wonder how to make the little hand
grinder's "bench vise insert" use more than one hole. One hole's working
great so far, but still, two holes would hold >4 times as good.
BTW, my "best" tool is the bench vise. ;)
Even he's showing how anything that can-be-clamped in the vise will-be.
I skipped through it in little steps but saw how he burned the corners of
the wood really bad. I say, use a brand new sanding disc for wood. :)
It's the only way to -quickly- take the extra wood off the butt end of a
knife handle you're working on. Used hoof rasps and sand paper and all
sorts of stuff but a brand new sanding disc can do it without scorching the
wood if you're careful.
I hacksaw off all the material I can then go at it with whatever works.
^^ -old- velvet mesquite from NM ...harder to work than oak or maple
After using the disc for wood save the disc to shape -aluminum-. :)
Took that silly looking script off the upper intake on my '91 5.8, lickity split.
No gumming up either.
Alvin in AZ
  #303
Old 05-07-2013, 07:21 PM
mercquicksilver mercquicksilver is offline
mercquicksilver is starting off with a positive reputation.
Alvin I am am putting a 6303 pilot in a 2000 7.3 F250. Should the bearing be flush with face of flywheel or pressed in further
  #304
Old 05-07-2013, 10:22 PM
Shove it in there as deep as it'll go. ;)
A 7.3 according the SKF and Rockauto don't use a big 6303 it uses the
little 6003.
I just pulled my FE and T18 apart and the 6303 is like new and so is the
transmission input shaft after 25k miles.
Haven't pulled the 351w and ZF apart yet, that rig's got the little 6003
bearing in it.
6003 = 17x 35x 10mm (.669x 1.378x .394")
6203 = 17x 40x 12mm (.669x 1.575x .472")
6303 = 17x 47x 14mm (.669x 1.850x .551")
A/C clutch+pulley bearing = 5106 30x55x23mm (my '75 and '91 ;)
Goes with my post #302 and 70BumpClubCab's post #300...
Alvin in AZ
  #305
Old 05-07-2013, 10:36 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Some woods will burn no matter what you do, especially fruit woods that have a lot of sugar in it like maple or cherry, or very dense hardwoods like rosewoods. The only solution with these woods is to sand with less and less pressure, finishing by hand sanding.
  #306
Old 05-08-2013, 10:53 AM
Cool, AX! :)
You've used a little handgrinder with a new-sanding-disc on wood too? :)
What you describe is my experience too. :)
->brand new<- sanding disc (or only used on wood) is a must, IME.
A friend of mine swears by flap disks on wood but I haven't tried it yet. :/
I will soon tho since me and my wife need to make a bunch of knives.
Canvas Micarta handles mostly I'm guessing, like this one...
http://www.panix.com/~alvinj/file12/Logan1.jpg
http://www.panix.com/~alvinj/file12/Logan2.jpg
http://www.panix.com/~alvinj/file12/Logan3.jpg <--front end of handle
http://www.panix.com/~alvinj/file12/Logan4.jpg
http://www.panix.com/~alvinj/file12/Logan5.jpg
http://www.panix.com/~alvinj/file12/Logan6.jpg
Used to work and work at grinding out the blades but that was before
the little handgrinders hit the market. ;)
All hard (teeth to back 63-65 HRC M2 high speed steel) power hacksaw
blades.
IME, that stuff makes a terrible gasket scraper... ;)
Hard HSS digs into cast iron like it's wood. LOL :)
Alvin in AZ
  #307
Old 05-08-2013, 11:12 AM
AXracer's Avatar
I have an MS in jewelry design with minor in wood design, and have studied and worked with a lot of common and exotic woods. I don't do much free shaping/sculpting on wood any more, more into lathe turning these days. My favorite way to finish hardwoods is by hand scraping, leaves a much more refined surface and really brings out the grain of the wood.
  #308
Old 05-29-2013, 08:05 PM
topmoo's Avatar
topmoo topmoo is online now
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Very true - sanding with any grit dulls and scratches the wood and closes the grain. Freshly planed or scraped wood with no sanding is by far the most beautiful look. Oil really brings out the colors and the depth of the wood. While I don't have a Masters, I do have many hours/years of woodworking and quite a few hours of classes through AWI at Pittsburg State U in Kansas. I am going to retire in a year or so and concentrate on woodworking NOT for somebody else, and build another Woodie or two (or more).
This was the first one that I built, for a client. A '40 Chevy with Ash and Mahogany. It began as a 4 door sedan.
  #309
Old 05-30-2013, 02:03 AM
wood.
Cool, you guys. :)
What about fine steel wool?
Results are something in between sanded and scraped?
Alvin in AZ
ps- Support the rear of the engine, don't take much, and on FE's
and FT's, use a 6303 sealed ball bearing for a pilot bearing! :)
  #310
Old 05-30-2013, 06:29 AM
topmoo's Avatar
You can use sandpaper, just start with 80 or so and work your way up with 100, 120, 150, 180, 220, to as much as 400, 600. Don't skip any of the grits. Each finer grit will take off many of the scratch marks of the previous grit. Steel wool leaves the oil it comes with and fine pieces of the steel that breaks off in the grain. It also is almost impossible to get a flat surface because where your fingers are is where the steel wool works as opposed to having a flat pad back-up. Scotch bright works better than steel wool. And always rub any abrasive with the grain, not across.
  #311
Old 05-30-2013, 10:14 AM
AXracer's Avatar
Yes, sanding will make the surface of wood smooth but it destroys the wood's beauty. Any sanding creates fine dust that gets pressed into the pores of the wood, the dust then obsures the fine character of the grain. it also "fuzzes" and spreads the cell walls. It's like someone putting powder on their face, it smooths over and blends everything together. Adding a finish turns the dust to mud permanently dulling the character. Scraping slices the wood's cell walls cleanly without fuzzing them or filling the pores, allowing the finest grain character of the wood to be displayed. When finish is then applied it fills the pores with transparent material which in turn allows light to penetrate and show thru the cell walls so they glow like near microscopic lanterns or lamp shades. It's similar to the difference between a true candy color paint job and an opaque paint, the difference is amazing.
  #312
Old 05-30-2013, 02:07 PM
topmoo's Avatar
True, scraping and/or a very sharp well set plane leaves a cut with no scratches. Alas, it is not always possible to do in every case, either because of time or configuration constraints (such as compound curves, inside corners, or enough hours in the day). When it is not, then sanding with the proper steps will produce a very nice finish with no noticeable to the naked eye scratches. It does dull the wood, but oil does help to bring much of it back. Still nothing like a perfectly planed or scraped piece. You don't want to sand part of a project and scrape or plane the other part - too much very noticeable differences.
  #313
Old 05-30-2013, 08:31 PM
AXracer's Avatar
In my experience it takes less time to scrape than to sand if you have a good set of sharp scrapers of various shapes. You only have to scrape the surface once, you have to sand it many times. I agree don't mix finishing methods, it will show.
  #314
Old 06-02-2013, 07:26 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
While trying to remove the very minty clutch and brake pedals from my 56 Merc,I discovered that after I heat the arms up the rubbers will come of very easy.After removed I used a Makita grinder wrench to spin off brake pedals from arm.
  #315
Old 06-04-2013, 01:15 PM
49 f-1 in progress's Avatar
49 f-1 in progress 49 f-1 in progress is offline
49 f-1 in progress is starting off with a positive reputation.
[QUOTE=Kusto;5216004]Seal Removal and Installation.
Another way to destroy an otherwise useful screwdriver would be to weld a small sheet metal screw to the end screw it into the seal and tug the seal out.
I have also used a body slide hammer if you got the room . No need to pre drill hole use a self tapper in your slide hammer and use the weight to tap it while you turn the handle to run the screw into the seal
S.O.S need help please read saauvenshine 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2016 10:22 PM
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 08:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 05:03 PM
ignition pickup????? sixshootingexp 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-16-2012 06:52 AM
12v to both neg and pos side of coil army89 1967 - 1972 F-100 & Larger F-Series Trucks 12 05-16-2011 08:23 PM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
