Cool Tips and tricks - Page 17 - Ford Truck Enthusiasts Forums
  #241
Old 09-04-2012, 08:17 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quote:
Originally Posted by medctr1 View Post
No noticeable coolant loss or I figured it had to be a couple of bad exhaust valves. I also thought the bad exhaust valves would cause backfiring. Also tried the paperbill trick on the tailpipe exhaust where
you put a paper bill near the end of the exhaust. It should just blow away from the exhaust pipe. If it blows away and comes back a little bit, it indicates a burnt valve allowing suction in the exhaust system when its piston is in its downstroke. At least thats how I understand it.
There is not much "meat" in the gasket between the valve areas of these engines. No coolant passage there. I've seen more than one leak in this area many years ago when I played with the flatheads. Retorqueing the head may show a change but probably not a permanent fix.
  #242
Old 09-08-2012, 12:08 AM
medctr1's Avatar
medctr1 medctr1 is offline
medctr1 is starting off with a positive reputation.
Quote:
Originally Posted by petemcl View Post
If you have a vacuum gauge this chart should help (old school high tech):
I hooked up a vacuum gauge off the vacuum wipers. EZ.
gauge holds steady at 18, if I do a quick punch of throttle it goes 10-22 then back to 18.(if I increase rpms to 2000 or so it increases to 20 then drops back to 18) I do not notice any dropping or floating of needle...well maybe a half a unit at most. According to chart you gave me I believe I show a "normal motor" but I still have 50psi in cylinders 5&6 and good compression 105-115 in the others. So..............am I reading the gauge correctly?
  #243
Old 09-08-2012, 08:31 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
These readings are on an engine at normal operating temperature. Make sure that your temp gauge shows that. Remember that these flatheads take a while to warm up.
I'm not sure if your engine has been sitting for a while or not but these ring might just be stuck. Clean oil and regular use might free them up. I would be careful using any "snake oil" (and there are lots out there that make outrageous claims) as you might have unintended consequences using them as most are designed for modern engines.
  #244
Old 09-08-2012, 12:41 PM
medctr1's Avatar
newbie lookin at vacuum gauge
Maybe I can't read the second chart, but I thought it was saying 4-25 was normal when you punch it. I sure expect the vacuum to show something ,considering the compression in 5&6. is low.
  #245
Old 09-08-2012, 01:24 PM
raytasch's Avatar
In your troubleshooting, remember that vacuum drops to near zero at WOT. Sounds to me like you're reading the vacuum gauge right. Why not start a separate thread.
  #246
Old 09-08-2012, 02:54 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is online now
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
I don't think this has been mentioned before:
Frame swaps are almost always impossible and usually end in failure and frustration. Use the original frame and improve upon it. Search for FTE posts about "frame swaps" and read every one of them.
Starting a new post is a very good idea for two reasons, it gets this thread back on point and if you have a separate thread with a topic specific title more people will see it and chime in with more help.
  #247
Old 09-08-2012, 03:29 PM
medctr1's Avatar
new thread
Quote:
Not sure how to start a new thread...look at it later this weekend. thanks.
  #248
Old 09-08-2012, 03:41 PM
bobj49f2's Avatar
Just go to the main page of the '48-56 board and click on the just above top of the discussion board. A new will pop up and you enter a subject title and below in the box enter your message, just like you did here.
  #249
Old 09-09-2012, 10:44 AM
petemcl's Avatar
Still Learnin'
Yes, but you only have 2 cylinders with a problem not all 8. And you never reach 25. Do all the other test read normal? Ray is right. This thread is for "Cool Tips & Tricks".
  #250
Old 09-09-2012, 08:53 PM
raytasch's Avatar
Help for Windshield Wiper Blades
For those who have a vehicle that does not get driven for long periods you've probably had the problem where the windshield wipers take a "set" and then jump, skip, and vibrate when you use them after a long dormancy. When I park my seldom used vehicles I place a small block under each wiper arm that keeps pressure off the blade thus preventing it from taking the "set". And if the vehicle is stored outdoors, consider placing a piece of pipe insulation over the blade, keeping the sun off. And RainX works good for these seldom used vehicles.
  #251
Old 09-09-2012, 09:06 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Thanks, good tip. Here in Houston with the hot sun we get, I go through a couple of sets of wiper blades a year on three vehicles. And if I don't use RainX at least one more set.
  #252
Old 09-09-2012, 09:18 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Here if the vehicle is parked outside for a period of time the heat and tree sap "welds" the edge of the blade to the glass, so when you turn them on it rips bits of rubber out of the edge and the blade streaks from then on.
  #253
Old 09-10-2012, 10:45 AM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is online now
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Where I grew up in Imperial Valley, it only rains about once a year. So we routinely just removed our wipers and left them in the trunk. You just had to remember to reinstall them if the forcast called for rain. Jag
  #254
Old 09-17-2012, 05:32 PM
trueblueovalguy trueblueovalguy is offline
trueblueovalguy is starting off with a positive reputation.
a piece of rubber fuel hose cut to the proper length and slid over the drill bit to control depth.works great and saves trees.
  #255
Old 09-18-2012, 08:31 PM
AXracer's Avatar
I wrap a piece of masking tape around the bit with the end folded back on itself to form a flag. When the flag starts brushing the filings away around the hole I know to stop.
'89 5.8L no start, no spark 1nwmike 1987 - 1996 F150 & Larger F-Series Trucks 8 04-15-2016 09:07 PM
S.O.S need help please read saauvenshine 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2016 11:22 PM
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 09:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 06:03 PM
84f150 charging system blues doug84xlt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-30-2004 04:04 PM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
